mega squirt in phoenix - FirebirdV6.com/CamaroV6.com Message Board
  • mega squirt in phoenix
    anyone in phoenix running ms i have ms1 with a version 2.2 board and am trying to figure out the spark mod a picture would be great thanks in advance
    Re: mega squirt in phoenix
    Are you talking about the internal MS board modifications? Or the wiring from the megasquirt to the ignition system on a 3.4L camaro?
    Wayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>
      sorry im talking about the board mod ive just found a couple of different answers wondering which is right and i cant seem to communicate with my ms and am not finding much help plenty for msII but not for 1 thanks again travis
        I modified my board for spark control just like this:
        http://home.att.net/~basic-4/megasqu...etup-GMDIS.htm
        That's on my site.
        But it's the same way as shown here and this one has some pictures:
        http://megasquirt.sourceforge.net/ex...tup-gmdis.html
          As for the communication problem, is Megatune giving you any type of error messages?
            thanks for the diagrams
            in communication settings i tried to verify ecu communication and it failed im not positive i have the proper serial cable but i am pretty sure. I dont have ms fully wired in just power and ground to establish communication that should be enough right.
            thanks again
              Yea, just power and ground should get it up enough to communicate...you'll just get junk readings on the gauges since the sensors aren't attached. The serial cable needs to be a stright-through cable, IE: pin 1 to pin 1, pin 2 to pin 2, etc. It CANNOT be a null-modem cable.
                Do you have a 9-pin serial port on your computer, or are you using a USB->serial converter?
                  ive got a serial port on my computer, do I need to setup megatune some how or no?
                    Just make sure your serial port is working and that in megatune communication settings the com port is set to the same as your 9-pin serial port.
