Alright, before I get my car dyno tuned after I do a turbo, rockers, cam, heads, gears, lsd, injectors, fuel pump, springs, stall converter blah blah blah, install would the standard HP tuners be fine or should I really go with pro? I'll learn about it when the time comes but first things first and I'm just trying to get everything together.
Before I get it dyno tuned..
Re: Before I get it dyno tuned..
are you going to be getting a wideband for tuning?
The pro allows you to hook up the wideband directly to it. If you go standard then you have to hook the wideband up through the egr wire and disable your egr. Then insert a table to read the wideband.
Originally posted by Blizzard242 View PostI'm eliminating the egr anyways.. but besides the black box are those extra direct hookups the only extra features pro has?
I have the PLX wideband as well as quite a few other guys and we all like the units :)
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...4 days ago
