where would be the best place for me to get a pcm?
i tried a site called intense-racing they want 99$ for a programmed pcm that works with their stage 1 n/a cam. any suggestions?
Give us basic specs of your car and what your wanting the PCM to accomplish
i want to get rid of topspeed and rev limiter, i want to redo my air fuel ratio i want it to get rid of the codes that deal with the exhaust because i'm going to be running no cat. i want something that will run with a cam but i dont know which cam to get either.
its a 2000 manual. the t-5 and it has 308 gears i believe and as of right now i have a magnaflow cat-back with a magnaflow high-flow. but i'm taking the cat off soon
no i'm new to all of this and i'm going to carlise on the 9th 10th and 11th of may soo i need to get this stuff fast. soo any advice from you guys is alot of help to me.
I suggest that you call some local speed shops and ask them to tune your car and not do it yourself. Not being rude, just being straight with you. You want it done fast and dont have the knowledge to do it yourself, doing it yourself you'll need time for trial and error.
If you haven't bought everything already, I highly doubt it will be ready in 2 weekends. You can buy HP Tuners basic VCM suite. It will have everything you need. As far as a cam goes. I'd find a custom grind. Look around and see what other people are running. Daily driver?
