Hey my low oil light keeps comming glowing on my 94' Camaro....Where i sthe sensor because eventhough I know there is oil in the car and it has an oil leak. The light will coem on every other time I crank up the car, and another thing how much would that sensor run me about?
Low Oil light
Re: Low Oil light
^ easy fix.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Low Oil light
That's another way to do it. But if you want that light to go away check your oil level sensor. It is a easy fix it takes less than 1hr to do it. Just jack up the car grab a wrench and take that sensor out and buy another one and put it in. It is really easy. The only problem you may have is taking the wire off from the sensor. either than that it would be easy.
Re: Low Oil light
when i got my firebird the low oil light would just stay on even though the oil level was fine. turns out the sensor in the side of the oil pan was unplugged. so i spayed it out with some sensor cleaner, plugged it in and it was fine. chances are it's just got gunk on it or came unplugged. just check under your car like insaneABOT said the oil level sensor is on the driver's side of the oil pan
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...4 days ago
