Hi you all. My '97 3.8l has the SES on. In the scanner appears a problem with the O2 sensor(s). My question is: how many O2 sensors does my camaro has? If more than 1, how can I know which is the problem one? (btw, I´m new in the forum) :cool:
O2 sensor(s)
Re: O2 sensor(s)
you will have 3 02 sensors.... one on each manifold, and one after the cat. converter... your scan will show either:
Bank 1 sensor 1: Driver side header
Bank 2 sensor 1: Passenger side
Bank 1/2 sensor 2: Post- Cat.
whether it be bank 1 or bank 2 AND Sensor 2 you know its your post cat sensor...
Re: O2 sensor(s)
Does the above apply for a 1999 Firebird as well? I have P0155 02 Bank 2 sensor 1.Last edited by 1999V6; 07-05-2008, 07:56 AM.W68, K&N, Flowmaster, Walker Cat, 18 x 9.5 Chrome Y2k C5\'s w/ 275/35/18 Kumho 712\'s, Susp Tech 1.2 inch drop front, 1.7 inch drop rear, Hotchkis Adj PHR,Slotted/Cross Drilled Rotors<br />Hawk Pads<br />Pics: <a href=\"http://community.webshots.com/user/franjobc-date\" target=\"_blank\">http://community.webshots.com/user/franjobc-date</a>
Re: O2 sensor(s)
Thanks Rad it was that one.W68, K&N, Flowmaster, Walker Cat, 18 x 9.5 Chrome Y2k C5\'s w/ 275/35/18 Kumho 712\'s, Susp Tech 1.2 inch drop front, 1.7 inch drop rear, Hotchkis Adj PHR,Slotted/Cross Drilled Rotors<br />Hawk Pads<br />Pics: <a href=\"http://community.webshots.com/user/franjobc-date\" target=\"_blank\">http://community.webshots.com/user/franjobc-date</a>
Re: O2 sensor(s)
my 97 has 4 O2 sensors. one on each header, one before the cat and on after the cat.1997 3.8 5-speed Camaro<br />BMR STB, LCA\'s, SFC\'s,Panhard bar, Torque arm,1LE sway bars<br />Headers, SLP cold air, Flowmaster catback, takeoff LSD, Eibach pro springs<br />Hurst shifter, 01 Z28 guage cluster w/ white face overlays, billet grill w
Re: O2 sensor(s)
You have one on each manifold one before the CAT and one after the CAT. The is nothing near the TB. There is a coolant temp sensor below the TB.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: O2 sensor(s)
Originally posted by savagecamaro96 View Posti see that but thats not my question, i asked what they were.
I'm going to take a shot in the wind and say you're asking about the MAF sensor and the coolant temp sensor.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
