bigger maf - FirebirdV6.com/CamaroV6.com Message Board
bigger maf
  • bigger maf
    what and all do you have to use to run a bigger maf?
    like if i get an ls1 can my computer relearn it or will i have to get it retuned for that? whats needed to run an LS1MAF and what can it handle?
    2001 Camaro 3.8 A4
    1991 3000GT VR4
    2001 Mitsubishi Eclipse GS
    Re: bigger maf
    you would have to tune for a different maf, not sure about the other stuff
      Re: bigger maf
      will it plug right in or do i need an adapter? is there one better than ls1 for not much more cash?
      2001 Camaro 3.8 A4
      1991 3000GT VR4
        Re: bigger maf
        what are you running that requires a biffer MAF? Our MAFs are housed in the TB, so to use a LS1, you need to remove the stock one, plug the hole, and place the LS1 MAF and housing somewhere inline between your air filter and TB; the wiring might be abit different though, but you can probably buy an adapter somewhere (ZZP, IIRC has them). As for tuning, there are people who've done it, IIRC, but there are others who are still struggling with it.
        ~97 3.8L V6 Camaro~
        A few things
        Only Member of Team Hooker?!?
          Re: bigger maf
          you would first need hptuners to tune it. Second it is not the same as the 3.8 MAFs as the 3.8 maf mounts into the TB and the LS1 mounts inline with the intake.
          But why would you be looking at a new MAF unless you are maxing out the current stocker with FI or something pushing crazy air. Spend your money on other things first. A new MAF is not needed if you are NA.
          http://www.bowtiev6.com/
            Re: bigger maf
            its not gonna be NA next week i haave a guy that does my tuning for me at his shop i know the ls1 maf wille go outside the TB and dmw maxed his out so if ihave to pay for a new tune might as well do this at the same time..
            2001 Camaro 3.8 A4
            1991 3000GT VR4
              Re: bigger maf
              can i use a 3 or a 5 wire maf? with the 5 wire i just have to get the adapter correct?
              2001 Camaro 3.8 A4
              1991 3000GT VR4
                Re: bigger maf
                I really don't see you maxing the maf on the powerdyne, even if you did it would be very little over, which you would use hptuners add vs. rpm to add the fuel, I rarely saw 37.00 in my maf readings and that was at 9-11 lbs of boost. I know with my cam I saw less on the gauge, but the power was still there. I wouldn't worry about maxing the maf with the powerdyne, if you run it at around 6lbs you won't max the maf. If you run it at a higher PSI you'll end up rebuilding the powerdyne more times than you will want to. So stay at around 6lbs and you won't rebuilding the powerdyne as much and you won't have to worry about the maf.
                  Re: bigger maf
                  well i have to pay for the dyno tune anyways and i can get a 3 wire dirt cheap so i might as well mod it and do it so i don't have to later on..
                  2001 Camaro 3.8 A4
                  1991 3000GT VR4
