OBD II Connector is no longer receiving power - FirebirdV6.com/CamaroV6.com Message Board
  • OBD II Connector is no longer receiving power
    Ok...this is the on-going saga of the non-emissions passing Camaro.
    So, since I cannot pass emissions, I cannot get the car's title in my name, nor can I get it registered.
    So, I take the car to get a 30 day tag for it, and stop by Autozone for a free OBD code reading. Low and behold, the OBD II connector no has no power.
    I disconnect/reconnect the cig lighter, verifiy that all fuses are still working, but the OBD connector is still not receiving any power.
    So, back to the garage tonight with my hammer and chisel to solve this new, totally awesome issue.
    Re: OBD II Connector is no longer receiving power
    emissions, clean or change out the EGR, all three 02 sensors. I believe there are 3, mine has 3, get a new cat convert. and exhaust.. you should pass with no problems..
    archer. that sucks about no power getting to the OBD-II plug. check wiring is all I can say and ground points.
    Archer
    MISC: 01 parts. Some interior, T top kit, seats etc.
    http://forum.camarov6.com/showthread.php?t=95347
      you sure all the fuses are good? the one fuse panel to the left of the steering wheel?
      90% of the time that's the problem
        and I stand corrected, its 4 o2 sensors.. 1 on each header, 1 before the cat and 1 after the cat..
          Archer
          thats not going to do anything, emissions is passed or failed by what the OBD system says
          if it isnt getting any power, the car wont pass
          you may, however be able to get a sniff test done.. but im not entirely sure how your state/county works with emissions stuff
            so if they cant read it, they cant pass it, dude that sucks, Im glad we dont h ave emission test here in ohio.. sorry to hear that man, I would take it to an electronic auto repair place and have them look into it. or hell even ask them, they might be able to tell ya what it is.
            But like meaty said, pull every fuse 1 at a time and check all of them even under the hood.
              yup you are correct, in 95+ cars they basically dont even do emissions testing.. the car does it for them
                OBDII connector draws it's power from the Cig lighter fuse. Check that.
                -<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
                  I have checked all fuses under the hood and to the left of the dash. All are in correct working condition.
                  However...and I am sure some may laugh or shriek at this...when I purchased the car last week, the radio power continually cut on/off randomly. So naturally, I figured it was the wiring, and checked the fuse box to make sure that the correct fuse (too large) was being used.
                  Sure enough, the fse box calls for a 15A (I think), and the guy had installed a 25. Nice...I thought, who knows what it could be now.
                  So I started invetigating all the fuses, and out of the 12 that were in the box, only 5 of them were setup correctly.
                  Some had a smaller fuse, and others had a larger.
                  So, taking logic by the horns, I went out and grabbed a few new fuses and went to work resetting them all.
                  The radio still cuts in/out, now the OBD connector is no longer working, and to my awesome suprise this rainy morning at 0500, the wipers no longer work.
                  So, needless to say, the car is on Craiglist for $2000 obo. If no one gets it in the next 30 days (when the temp tags expire), I will either dump $500 into getting it fixed, or burn it and collect...
                    thats horrible, electric wiring is the worst stuff to do in cars
                    if you have time on your hands you can take the dash apart and follow all of the wires and re do them
                    sounds like whoever you bought the car off of had no idea what they were doing, and cut/patched wires wrong
                      Might need a new PCM, or check the PCM wires to make sure they are seated correctly and the harness is tighten down on the PCM.
                        So, I checked the OBD connector during lunch yesterday, and sure enough, it now has power. Still have the SES light on, P0102, which is being checked by Napa tomorrow. They checked the MAF sensor last time I was there, but maybe they will replace it this time.
                        However, the wipers still do not work (need to check the relay) and now the dash lights are not working as of this morning.
                        This car is becoming more of a POS each morning, so...hopefully I can get everything working long enough to sell it for the $2000 I paid for it.
                          Thanks everyone for the troubleshooting help and suggestions. I really do appreciate them.
                            i seriously hate electrical issues.
