Hey just wondering where the kock sensor is located on the 3.8 motor??
Where is the knock sensor??
Re: Where is the knock sensor??
there are two, one on each side of the engine and they are on the side of the block
i have been trying to find these things for years. i have been under there looking for long time periods too. but it doesnt help when you dont know what your looking forHeady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
There is one in the same position on the other side of the block as well. 1 wire connection. Just under the freeze plugs.
With how cramped it would be with all the accessories, crossmember, and steering, it is probably pretty hard to find just looking under the car. I can't really say, my motor isn't in a Camaro :p
No thats a block heater if you have a electrical connector coming out of the freeze plug. The knock sensor looks exactly like the second picture with the threaded part screwing straight up into the block. Knock sensor has 1 wire per side. The knock sensor is right in the middle of the red circle :p
because i think my car is pinging,im getting a rattleing under load,and wanted to check them,my haynes manual says to check the resistance value of them but after getting under the car and finding them i see that theres only 1 input to it so what do i measure the resistance between?? i also took the car for a run with it disconnected and felt no difference,it didnt get worse and i still had no ses light??
yeah i just figured that,thanks, im getting 100k ohms so i geusse its not that one,the other one is hard to get at so i dont know what to do about this rattle/ping noise, guess ill have to let the pros handle it.
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.2 weeks ago
