basically it says the o2 sensor isn't switching back and forth from lean to rich enough in a 100 second period.
Maybe a bad sensor, maybe bad wiring, maybe an exhaust leak.
A vacuum leak could cause this but it would probably throw the other o2 off as well, so no worries on the intake side. If I were you, I'd start with checking the o2 sensors condition if there isn't an obvious exhaust leak.
And get a new valve cover gasket, it's an easy easy fix and not expensive.
