~Is my PCM bad?~ - FirebirdV6.com/CamaroV6.com Message Board
~Is my PCM bad?~
  • ~Is my PCM bad?~
    I decided to check to see if I could pull some codes. I know I had a good connection, jumped A+B terminals, it is the 12 pin so I know its the right procedure. And I couldnt even get a code 12! It did nothing, the SES just stayed on!
    This is in reference to this thread: http://forum.camarov6.com/showthread.php?t=94014
    94 3.4 M5
    Re: ~Is my PCM bad?~
    You have to use a OBD-I code reader.
    '99 Mountaineer AWD 5.0 - 4300K HID, Some Bolt-ons
    '97 RS - HPTuner, Bolt-ons
    '09 WRX - Aesthetic mods
      Thats not what Haynes says... It says jump terminals a and b and it should flash when ign is turned to on. Just like any other OBD1. Just like my 91 Camaro Ive done many times...
        listen to logger, hes right
          why does my haynes say otherwise?
            Because Haynes maunals are notorious for making mistakes regarding our cars, as well as offering ambibuous information on very detailed procedures.
            Get yourself a Chiltons.
              this scanner will work
              http://forum.camarov6.com/showthread...503#post888503
              if your gonna take it to a shop to get scanned save your $ and just buy a scanner.
                Thanks for the input guys. I believe the PCM is unrealated to my issues anyway...
                  but i'm sure the codes are.....
                    Well as you know I cant even get it to start. So who says there are any codes. And the fact that the battery just got repaced, Id go as far to say there a none...
