Need Help ASAP - FirebirdV6.com/CamaroV6.com Message Board
Need Help ASAP
  • Need Help ASAP
    Who can/is willing to provide me with a 1997 A4 vin #?
    I just bought hp tuners and I can't licence my car. I have a mail order 1997 pcm, however it has my 1996 VIN on it.
    GM told me they cannot go through there data base to give me a VIN, but if I come to them with a 1997 VIN then they can rewrite it for me....
    however, the guy said its still no gurantee it will work...
    Can anyone help me out?...I know its really sketchy asking for a VIN #
    here is a link to the thread if you need more info.
    http://forum.camarov6.com/showthread...d=1#post896509
    Thanks to anyone that can help...you can PM me the # if you wish...
    Re: Need Help ASAP
    Lots of 97 VIN's on ebay.
    2G1FP22K6V2130332
    2g1fp22k5v2134971
    This last one is Totaled
    2G1FP22K6V2119198
    All V6 cars
      Re: Need Help ASAP
      2G1FP22K6V2130332
      2g1fp22k5v2134971
      2G1FP22K6V2119198
      All V6 cars
      ahh Im told apparently this won't work now...well maybe...cause apparently I have a 96 OS as well?
      I am soo confused...like I have a 97 pcm...has a 96 vin...have no idea what OS it has...
        Re: Need Help ASAP
        I think your best bet would be to buy a 97 PCM and start from there. You apparently got a mess from PCM for less. As far as trying to tune it anyway.
          Re: Need Help ASAP
          OS maybe an operating system?
          I have a cleared 97 vin i'll give ya. Im going to trash the car. I just needed the front clip. then its going to the scrap yrd.
          let me know. hell I can even send ya the vin plate. lol
          Archer
          MISC: 01 parts. Some interior, T top kit, seats etc.
          http://forum.camarov6.com/showthread.php?t=95347
            Re: Need Help ASAP
            Archer
            Nothing to do with the VIN being clear. He needs a PCM that is not altered from stock.
              Re: Need Help ASAP
              remember when a dealer is flashing a new vin that the new vin must have had the same gear ratio as well as trans....
              When I first switched from 3.08 gears to 3.42 gears I had to find a 97 vin that was a y87 car and then they could flash it so that my speedo was correct. This was before hptuners was made
              http://www.bowtiev6.com/
                Re: Need Help ASAP
                I have 3.90 gears so I will not be able to find one with the same gears....tranny on the other hand has to be an A4 I know
                Archer, I will let you know my situation soon...would you happen to still have the 97 pcm?
                  Re: Need Help ASAP
                  Just get a 97' pcm download the stock bin. then make your changes then reflash the pcm with the new changes. My Hptuners will flash any 97' pcm so I never had any problems with flashing pcms, is the new system of Hptuners lock in only one vin then you can't flash any other 97 vins ?
                    Re: Need Help ASAP
                    The dealer can change only the VIN with a TECH II. The rest of the tune in the PCM would not be affected. The new VIN would have to match with the OP system in the PCM for it to fix his problem. His problem comes from HPT having safety's build into it to keep people from frying their PCM's.
                      Re: Need Help ASAP
                      Also GM dealerships can change Vins , I had it done once when I had a M5 at the time and I had a A4 pcm that needed to be reflashed to a M5, but I didn't know at the time I could do it myself. They charged me $80 if I remember correctly.
                        Re: Need Help ASAP
                        I can change the vin with pcm...except you need a licence...and I can't get that licence for the pcm cause of the 96 stuff inside...
                        I guess I will go to the wrecking yard tomorrow morning and see if I can nab a new pcm for cheap...what a P*ss off...good thing the cams not in and the car not being able to run...
                          Re: Need Help ASAP
                          Is your PCM a 97 pcm or is it a 96? Pcmforless should of sent you a 97' pcm if you order one from them.
                            Re: Need Help ASAP
                            it's a 97 cause its tunned... I get an error code saying invalid VIN/OS pair...I contacted them and sent them the file and they said that pcmforless put in my 96 Vin and probably a 96 OS and that only the pcm itself was a 97...so 97 pcm, 96 OS, and 96 VIN
                            apparently I was looking on other camaro forums and this problem is kinda common for us 96'ers
                              Re: Need Help ASAP
                              Can you download the current tune in it?
                                2 days ago
