does anyone knows whats the name of the little programer you plug in to your trani to adjust your gear changes????
programing question
Re: programing question
i dont believe there is anything that plugs directly into the trans. HP tuners has all the things you would need to to reprogram your pcm for gear changes. Or maybe a hypertech would work not sure
Originally posted by BAD BIRD View Postdoes anyone knows whats the name of the little programer you plug in to your trani to adjust your gear changes????
Mini-SRC - Speedometer Calibration
http://www.zzperformance.com/grand_p...=174&catid=107
Not sure if it works for the F body. I know others make them for trucks too.sigpic
BTW you don't plug anything into your trans for rear end gear changes
