Couple questions guys.
1) in my 1996 camaro I have 4 O2 sensors...can I install my wideband in the factory location just before the cat and connect it to my pcm so that the pcm takes data from the wideband and uses that info to adjust the afr more accuratly?
Is there a way where I can leave the stock O2 sensors in place and still have the wideband work with the pcm to help the afr while driving stay accurate. (make the car accuratly adjust to what I am doing faster)
2) If the wideband is installed permantly on the car...how does it hook into the EIO ports on hp tuners? or how can I read it with hp tuners if I do not go through the EIO things on the programer box thing...
the wideband is a non gauged LC-1 by the way
