upping spark - FirebirdV6.com/CamaroV6.com Message Board
upping spark
  • upping spark
    Ok, so once I finish getting my afr all dialed in, I want to begin adding spark timing....what would be the safest/most effiecient way to go about adding spark without sitting there for 4 weeks adding a point at a time, and without doing damage to the engine?...
    Re: upping spark
    I do mine by adding 2 degrees each time, only in the high areas where I would hit , then check for KR and watch my A/F. Since if you up spark you might have to add fuel. Once you get 1 degree in a box, then back it off by 2, to be safe this is in the high octane, I also use the smoothing feature too, then once done I copy/paste to low Oct. and then subract 3 to 4 degrees and smooth it out again and save it. Thats how I do mine. Good luck.
      Re: upping spark
      Subtracting -3 or -4 would be like adding 3 or 4 degrees
      End math rant, lol
      ^What he said is how I went about the tune as well.
        Re: upping spark
        So you guys dont add to any of the other spark tables...i.e. the IAT base, AFR correction, ECT spark ect...?
          Re: upping spark
          Is there a write up at all on this that people have found? I think it would be pretty tedius to tune through the octane tables...trying to remember when/where to add and subtract timing...
            Re: upping spark
            The AFR correction base table I have Zeroed. I have the IAT table almost stock, I did have to remove some timing when the IAT is over 86*F. The ECT table is stock.
              Re: upping spark
              would it be a good idea to leave all the tables that add timing (higher numbers) and zero all the tables that pull timing (lower numbers)...then just pull timing myself through the octane tables?
                Re: upping spark
                I zero out the section of the tables that the car will see under
                normal operating temps/conditions. I leave the extreme conditions
                alone just in case.
                  Re: upping spark
                  Guys which cells in the octane tables are for cruising? and which are for WOT...
                  I need to know on both the RPM side and on the g/cylinder side...
                  edit: I just want to double check to that adding spark to get power is actually subtracting it on the octane tables right? so 20 is better then 24 for instance?
                    Re: upping spark
                    you need to go for a cruise and see where you are sitting while cruising. different driving styles will hit different cells. No you add to the table, 24* is better than 20*
                    http://www.bowtiev6.com/
                      Re: upping spark
                      Crap...I went for a cruise and I logged info in the spark retard table. Every cell that I was hitting I went over to my high octane table and clicked add -2 to each of those cells....So I was going the wrong way this entire tuning trip...damn it
                        Re: upping spark
                        I only use high /low oct. tables , I think mine is set at 24 on high oct table at the highest point. which it still hits 26-27 degrees timing sometimes, low is set at 4 degrees lower at 19 at the highest point so it will give me some room if I get KR.
                          Re: upping spark
                          really? I have 49 degrees in some spots...
                            Re: upping spark
                            I'm talking about WOT timing in the lower right hand side of the timing tables. Then whatever your timing is at WOT is your timing. I don't see the need for 49 degrees of timing for any of the tables. I think my highest is 39 and that is from the stock timing setup in the low areas. The most timing at WOT should be 28 degress at max, anything above it you won't see anymore benefit from it. Also watch your KR if your running that much timing in some spots.
                              Re: upping spark
                              so far I have no knock anywhere...except the odd 1 degree that might pop up...
