:rant:I have this p0420 code and i've changed my cat 3x's and changed the 02 sensor last yr. Took it to advance and was told to clean the sensor, could i just have a bad sensor or how or with what do i clean it?:bs:
02 sensor
Re: 02 sensor
Yeah. Bosch O2 sensors tend to not last long and don't work very well in the meantime. I would suggest you try Denso or AC Delco 02 sensors and stay away from the Bosch.
RockAuto has them for a good price if you can't find any.'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
Re: 02 sensor
AC Delco O2's are nice , there is a website I posted in Gen. Tech where they are like $40 a peice.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: 02 sensor
Part # is in the post AFS75 for the front O2's. As long as you have the flat connectors and not the square type for the rear O2's.
I came across this website looking for AC Delco O2's, price seemed to be good so I thought I would pass it along, I just ordered 2 of the AFS75 for the front O2's, I was starting to get a low reading in bank 1 the drivers side, it wouldn't go past 900. Here is the website: www.getgmparts.com08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
