02 sensor - FirebirdV6.com/CamaroV6.com Message Board
02 sensor
  • #16
    Re: 02 sensor
    ok well i got the sensor and the check engine is still on dumb stupid ************************************* thing wat else can i do? i do my tune up and everything idk was else i can do and i have emission next month so i need to figure it out quick
    • #17
      Re: 02 sensor
      Did you reset your DTC's once you replaced it and then it came back on?
      • #18
        Re: 02 sensor
        I had a situation where
        i went into advance
        got my codes ran.
        it pulled a tps sensor.
        i replaced it.
        the next day
        it pulled a
        MAF sensor failure
        replaced
        the NEXT day
        i went back and it pulled an 02 sensor.
        turns out I RESEt the codes. and unplugged the battery and held the breaks in for 10 seconds..
        then POOF
        no more codes.
        sometimes the tps and maf sensors can SET off o2 codes.
        because mafs control the air to gas ratio and the throttle positioning sensor tells the engine how much VROOM it can do.
        since a bad maf sensor composes MOST of your engines info as far as fuel and air.
        sometimes the INPROPER mixture can be read by the o2 sensor and THERFOR.
        the o2
        sensor is like WTF. and says HELLO THE WRONG MIXTURE IS PASSING through me.
        get it worked out up there.
        so then while its pitchin a fit your freakin because you think its bad.
        OH and btw
        a bad maf sensor CAN be bad and NOT pull a code.
        (did it on mine)
        so i would have that checked.
        oh yeah and clean the maf sensor off with MAF sensor cleaner
        or just reguler electrical terminal cleaner.
        THEN reset the codes.
        and tell me what happends
        • #19
          Re: 02 sensor
          wats DTC'S? i didnt disconnect the battery i work too early and wont have time in the morning to connect the battery
          • #20
            Re: 02 sensor
            i went into advance
            got my codes ran.
            i replaced it.
            the next day
            it pulled a
            MAF sensor failure
            replaced
            the NEXT day
            then POOF
            no more codes.
            the o2
            OH and btw
            (did it on mine)
            ill try that but isnt the MAF like expensive ill change it when i can or have money
            • #21
              Re: 02 sensor
              Just have autozone clear the codes for you, DTC is just another term for trouble codes. Then see if it stays off before throwing anymore money at it. The maf has it own trouble code if it fails and it is not a O2 sensor PO420 code.
              • #22
                Re: 02 sensor
                i tried that they said "oh we dont do that" i told him they did it before but i guess he was being lazy sorry lazy worker:twak:
                • #23
                  Re: 02 sensor
                  Just buy a small scanner they sell on ebay for like $30 or habor freight, good investment , I kept one in my car for years. Since I would be driving a some code I forgot to delete with HPtuners would pop up and I would scan it and then after 3 times it would delete it for me while driving.
                  • #24
                    Re: 02 sensor
                    ok cool ill do that thanks for the info:bowdown:
                    • #25
                      Re: 02 sensor
                      it popped up again :bs:and i delete it and again it pops up so hopefully it will stop :rant:
                      • #26
                        Re: 02 sensor
                        You might be running too rich or have oil blow by causing your O2 to go out. But just keep a eye on it or see if someone has a scanner that can read the output on it to see if it is in normal range while at idle and driving and WOT.
                        • #27
                          Re: 02 sensor
                          how can i run to rich? i change my plugs not to long ago i have msd wires and coils. so ur saying i havw a blow gasket? well last yr when my mech i go to scanned it and said it running too low so i vhanged the sensor and ran low but went away i think cuz then i had a vapor leak so i fixed that then this code came back so i changed it again but i havent scanned it yet so im lost :(
                          • #28
                            Re: 02 sensor
                            ok well i went to my mech today and he said i have too much air in my engine idk how thats possible that the lt trim or something is to high and sl trim is normal and also my headers o2 r fine the r around 800 - 900 and the back one is at 189 and stays there for awhile he said maybe my MAF is acting up or MAP is not working didnt know wat a MAP was but idk im driving it around to see if pops up again which im pretty sure it is so any clues or ideas it might me be?
