p0171 and p0174 after supercharger???? - FirebirdV6.com/CamaroV6.com Message Board
  • p0171 and p0174 after supercharger????
    two weeks after the supercharger install. SES light
    need help with this codes p0171 and p0174
    i dont know what to do ????
    any ideas??
    headers, high flow cat, slp loudmouth
    powerdyne supercharger 6psi
    GT2 cam. all done by myself :banana:
    Hell yea
    Re: p0171 and p0174 after supercharger????
    bank 1 and 2 lean conditions I believe are those codes if I remember correctly. Did you do any fuel upgrades to compensate for the SC?
    http://www.bowtiev6.com/
      nope Just the hp tuning
      any other upgrades I should have done???
      Hell yea
        what is your injector duty cycle at when driving?
        Stock injectors and fuel pump?
        If no fuel upgrades you will have issues with lean. You need fuel upgrades when doing FI, whether it be FMU or injectors
          i think 80%
          I'm waiting on some 36lb GTP injectors that will go in as soon as i get my cam
          that should take care of the problem, don't you think???
          Hell yea
            If the injectors are not maxed out then tune your MAF table. Those codes set when your fuel trims stay above +16.
              Originally posted by BAD BIRD View Post
              i think 80%
              you need to tune your fuel and get your a/f ratio lined up for having the extra air.
              GTP injectors will be fine
