How do you get your car to put out what it is really suppose to? I think you would ahve to remove the speed limiter, but i have no idea how any suggestions?
How do i remove the speed limiter or governer?
This topic is closed.
[ May 03, 2004, 11:40 AM: Message edited by: andrew.brandon ]95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
Re: How do i remove the speed limiter or governer?
I also have been looking for options for removing the speed limiter. I found this post in a search i was doing.
Whats the best way for a 1996 Camaro. Do I have to update my ECU to a 1997+?
Whats the deal? and if a newer ECU is needed thats fine, but what programer or software is the best/lowest cost???
Thanks! :DMSN: inynn666@hotmail.com<br />1996 Arctic white -3800-<br />Pacesetter Headers & Y-Pipe, CAI, LS1 Dual Exhaust, LS1 Driveshaft<br />*15.17 @ 95MPH*
Everything you guys are asking is covered in the tuning section of our forums. Please go there and do a quick search and read some stickies. Thanks
