which o2 sensor is which? - FirebirdV6.com/CamaroV6.com Message Board
  • which o2 sensor is which?
    Ok so I got a p0137 code which is Bank 1 Sensor 2 low voltage. I need to know which sensor this is, this is how I think it should be:
    Bank 1 Sensor 1 - Drivers Manifold
    Bank 1 Sensor 2 - Pre-Cat
    Bank 1 Sensor 3 - Post-cat
    Bank 2 Sensor 1 - Passenger Manifold
    Is this correct? I have done some searching and found conflicting answers.
    Also could an exhaust leak cause a my wideband to read lean and maybe even set this code?
    Thanks.
    Re: which o2 sensor is which?
    i dont think there is a pre cat sensor, i dont remember taking one out when putting my headers on
      this is on a 97 bird. we have 4 sensors.
        I'd fix it by deleting the sensor 2 and 3 codes from the tune.
        They're not really important. But I'm not running a catalytic
        convertor either.
        Fix your exhaust leak, reset the codes, and see if it comes
        back.
          Well I drove 400 miles after clearing the code and it still hasn't come back. Haven't got the exhaust leak fixed yet, but its next on the list. I also deleted the bank 1 sensor 3 codes, because if I am correct that is post-cat and I don't have a cat either anyways....but no new sensor 2 codes so I guess I will just see how it goes.
