P0327 how to fix - FirebirdV6.com/CamaroV6.com Message Board
P0327 how to fix
  • P0327 how to fix
    im getting this code
    P0327 Knock Sensor Circuit Low Voltage
    P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
    can someone tell me how to fix it ????
    headers, high flow cat, slp loudmouth
    powerdyne supercharger 6psi
    GT2 cam. all done by myself :banana:
    Hell yea
    Re: P0327 how to fix
    PO327 could be a KR senosr unpluged or if you have messed with the KR decay in Hptuners to make the KR sensors less sensitive. On mine I use resistors and have my KR sensors reduced 40% and mine would throw the low voltage so I just put No Error reported on the code. My car will still show KR just not as sensitive, no audibile KR or anything like that. The other don't know for sure but I think is a O2 votage, so I would first check all the connections and connections at the PCM to make sure wires are not pintch.
      where is the KR sensor located???
      Hell yea
        Theres 2 one on each side of the block.
          i will see if i can find were this are located
          Hell yea
            could it be the tuning ????
            Hell yea
              If you messed with the Kr decay rate etc. in Hptuners it might other than that a bad KR sensor or loose wiring.
