Loss of power, P0300 pending - FirebirdV6.com/CamaroV6.com Message Board
  • Loss of power, P0300 pending
    I have a 2002 Pontiac Firebird V6. The other day after getting off the 4 lane, I had to step on it. But not much happened. I ended up getting the service engine light flashing for a moment. (P0300 code pending, random and multiple misfire). Put car in shop and fuel filter was stopped up. Shop replaced it. Driving to work today, it does not have much power and when I opened it up, service engine light flashed a few times and had a P0300 pending code. I used fuel system cleaner and filled up with premium gas at lunch. It still is not wanting to run right (not much power). It will get up to highway speed (70) with not much problem but not much power when I accelerate and rpms go up higher than when it was running correctly. 124,500 miles and I just posted on here about a rattle that takes place around end of transmission and around exhaust. It only lasts up to about 2 minutes at the most when engine is cold. Makes me wonder if it is the cat convertor.
    Re: Loss of power, P0300 pending
    your cat could be the cause but it would throw an emissions related code for sure
      how old is the cat?
        Original cat. On the way home on the four lane, i got up to 90 before the service engine light came on. Seems to be running a little better with a little more power but gave code P0304, misfired cylindar 4
          same problem on a 01 malibu 3.1 it was the cat..
          2001 Camaro 3.8 A4
          1991 3000GT VR4
          2001 Mitsubishi Eclipse GS
            p0300 is a cam code u only get those wit bigger cams usually or theres a prob with it
              wtf are you talking about, p0300 is a misfire code and doesnt have anything to do with a cam.
              I would check, spark, wires, fuel pressure, o2sensors, and cat.
                thats a code that i heard often gets thrown with a cam and yes i would change the coils out cause i checked mine a while back and it said they were fine but i was still missing after i did my plugs and wires so for the hell of it i swapped out for new acdelcos and it ran great after
                  sry for faulty info
                    plug wires that would be my first guess if that aint i check the plug then coils
                      you can try switch the coils around to see if the misfire jumps to a different cylinder other then #4
                        Thanks for all replys!
                          fogman, did you get this fixed? If so what was the resolution? I just got the same thing on mine, knew it was coming though. It did the same thing 3 years ago but that time it gave me more time to plan to repair it now I'm having to scramble to get parts and time. GM should have come up with different level idiot lights. One that starts out hey idiot this needs to be fixed and progresses to hey stupid your car is gonna break.
                            Update: it was the cat. converter. I had it replaced and the car will now run like it is supposed to.
                              thanks for updating, on mine it turns out it was the number 2 & 5 coil pack. New plugs wires and a coil pack and she's back to running. Still feels sluggish but I may just be wanting her to be something she's not.
