Well my amp is onlya 400w, and I know it's not the headunit. But still when the sub hits my entire dashand headlights dim badly. I'm thinking ground right? But where's a good spot? I've got it on the seatbelt mount..
Lights dimming
Re: Lights dimming
Your Lights are dimming cause of the voltage drop when the bass hits, how old is you battery? I would take it to somewhere like auto zone and have your alternator and battery tested, Also get a .5 or 1 Farad capacitor and the will help. Also add a second chassie ground to your battery.
Re: Lights dimming
I would still have the charging system tested unless you bought an alternator from the dealer it is most likly a reman and ive seen them bad out of the box before.
Here is the Big 3 from LS1TECH
As I posted before #2 I believe is the most important I have done 1 and 2 on my car
1. Battery Positive to Alternator Output
2. Battery Negative to Chassis Ground (used stock chassis on driver's side)
3. Chassis Ground to Engine Ground (remove rear alternator bracket, run a wire from where the bracket bolted to the engine to the stock chassis ground location on passenger side)Last edited by sweetride98; 07-28-2011, 10:17 PM.
Re: Lights dimming
Doing the big 3 should help also a Optima yellow top batt. esp, if your turning up the bass.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
