Speaker help - FirebirdV6.com/CamaroV6.com Message Board
Speaker help
  • Speaker help
    This is for my 08' Silverado with a BOSE system, I want to add a amp and some 6X9' s under the rear seat, how do I get a signal for the Rca's off the Bose system? I know how to wire the power and ground and 12volt switched.
    Re: Speaker help
    i believe you need a "line out" converter....your doing all that because you want to keep the stock stereo system right?
      Re: Speaker help
      Yes, I like the bose system just need some back speakers, its a ext. cab so I want speakers in the back. Thanks for the response.
        Re: Speaker help
        noo problem...thats definitely what you need though...but look into a better brand with that...like JL etc...
          Re: Speaker help
          Does that just add on to the existing wires to the speakers, like a T.
            Re: Speaker help
            yep thats correct..just splice it into the rear speaker outputs...coming from the stereo itself of course
              Re: Speaker help
              Sounds good , thanks
                Re: Speaker help
                You don't have to run RCAs.
                  Re: Speaker help
                  How else would I get a signal for the amp?
                    Re: Speaker help
                    Since you're running 6x9's instead of a sub, I wouldn't go with RCA's honestly. But you just have to find an amp that either has inputs that can be swapped, or one that has inputs that are just speaker wire, and the amp just boosts it and puts it to the speakers. I can run either way on mine, it's just 2 screws.
                      Re: Speaker help
                      I'm going to be running my PPI 2300 am amp. So its just RCA's coming out of it.
                        Re: Speaker help
                        Check if there's a switch that says input on it, if there is the RCA's can come off, and speaker wire inputs can go in. I'll try to get a pic of mine when I get outta bed.
                          Re: Speaker help
                          I know theres no seperate inputs on it, I have had it since 1992, lol
                            Re: Speaker help
                            Yeah well I was -1 in 92...
                              Re: Speaker help
                              You suck! LOL I'm still not old...
