subwoofer wireing questions..... - FirebirdV6.com/CamaroV6.com Message Board
  • subwoofer wireing questions.....
    ok the specs for this amp i have is 450x1 at 4 ohms and i have a 10 inch rockford fosgate p3 is a dual 4 ohm voice coil.....my question is how do i go about wireing that to the amp to get the most power from it...if someone could like maybe do a quick sketch or something on the paint program on their computer id appriciate it alot.....thanks.....
    Re: subwoofer wireing questions.....
    with A 4ohm dvc you make it into one 8ohm or one 2ohm ...
    for the "most power" run at 2ohm ...
    amp + to all subs +
    amp - to all subs -
      ^Yup, and hopefully the amp is fairly stable at 2ohms. Thats one problem you can run into with DVC subs and some amps.
      \'98 Camaro V6<br />Appearance... pleasing<br />Performance... just a little extra air.
        so just wire it up like a regular speaker one wire going to the positive and negative for one coil and another wire for the other coil or do i need any of that like jumper wire type stuff......do you think you could do a quick sketch on paint???
          All your wiring answers are within here http://crutchfield.custhelp.com/cgi-...i=&p_topview=1
            Wire like so...
            <b><i>Don\'t Ever Judge Me</i></b><br /><a href=\"http://www.cardomain.com/id/earnhardt132000\" target=\"_blank\">\'96 Firebird Y87 3.8L V6 5spd</a><br />--No mods as of yet, shoot me some ideas if ya want.<br />178,000 miles and counting
              what kinda amp you runnin'?
              Lounge Moderator
                Originally posted by Earnhardt132000
                Wire like so...
                that would be exactly how it is as of now.....
                its a cheap lightning audio LA.150.2 all i could afford at the time
                its 150x2 at 2 ohms
                and 450x1 at 4 ohms
                  but crutch fields diagram is differant than what i have
                    its 150x2 at 2 ohms
                    and 450x1 at 4 ohms
                    Oh, you better be careful then. If you are bridging a stereo amp, the amp will see half the mono load. For example, if you wire your DVC sub to a 2 ohm load and bridge your stereo amp, the amp is going to be running at 1 ohm. With that amp, I'll bet my left nut 1 ohm is a bad, bad, bad idea.
                    Lounge Moderator
                      its 150x2 at 2 ohms and 450x1 at 4 ohms
                      Just an FYI Lightning Audio is a division of Rockford corp. ( RF )
                      if its a 2ch just run at at 4ohm x 2
                        what would be my best wireing setup post up a diagram if you can....thanks
                          ya i knew that its just a really cheap LA
                            Just go here and pretend ch1+2 and ch3+4 are your left and right outputs.
                            This is not the most powerful setup for this amp, but your only option is to run 4 ohms.
                            http://www.x-bb.org/~woosey/VC%20diagram.JPG
                            Lounge Moderator
                              its only a two channel amp though
                              so how would it look if i were to do it on a two channel and what will give me the most bass besides a new amp lol....
