Just like that diagram. pretend ch1+2 is your left + and - and ch 3+4 is your right + and -. Doesn't get much easier. Your amp has two channels, your sub has two voice coil. Hook one to one and the other to the other.
If your lucky, you might RMS 75-85 watts out of it.
well that sucks can you help me with one more thing what is a cheap amp that can pump this sub good and put good wattage to it.......i dont have alot of money but can scrap up some
No prob. I would almost just run it in 4 ohm stereo mode for now. Either that or look for a mono block sub amp that's 2 ohm stable. Something like RF's Punch P3001 would be nice. It would hit the P3 with an RMS 300 watts at a 2 ohm load. Nice, and you would keep it all RF.
Any of MA's HK series will work (they're all 1 ohm stable). The M1900EX is a 2 ohm mono block, which will work as well. Are these MA's as powerful as they boast? The smallest one is the HK398, which is claiming 1 x 600 watt at 2 ohm.
I say on that ten, try the HK398. Then parallel the sub into a two ohm load and bridge the amp into a 1 ohm load and you got it maxed. Even if 1 x 600 is max rated, you'll still net out fine for a single 10.
