which amp - FirebirdV6.com/CamaroV6.com Message Board
which amp
  • which amp
    I wanted to know which one of these amps would you all recomend me to use with my two kicker cvr 12 4 ohm subs.I already have them both in my possession the amps are a kenwood kac -8151d , and a dubmag audio, my cousin sold it to me for 30 bucks its the dub8001 .I looked up the specs on both and the kenwood puts out 500 watts at 1 ohm and the dub says it puts out 800 watts at 4 ohms and it is not 2or1 ohm stable. Which should I use that will make the subs hit hard. Thank for all of your help!
    Re: which amp
    are the subs dvc ?
      Re: which amp
      yes they are dvc
        Re: which amp
        Originally posted by 93witemaro
        specs of both and the kenwood puts out 500 watts at 1 ohm and the dub says it puts out 800 watts at 4 ohms and it is not 2or1 ohm stable.
        if kenwood is 500rms and the dub 800w max ... go with kenwood at 1ohm
        if not go with dud runing it at 4ohm
          Re: which amp
          the dub is rated at 800 watts rms at 4 ohms, but do you think it really puts that out,I looked up the kenwood and was tested and put out 517 watts rms at 1 ohm
            Re: which amp
            I looked up the specs to... I got 2 sets if specs:
            for dub8001
            Class A/B MOSFET Circuitry
            PWM MOSFET Power Supply
            Double Sided Glass Epoxy Circuit Board
            THD: 0.02%
            S/N Ratio: >100dB
            Frequency Response: 10Hz - 40KHz (+/- 1dB)
            Variable 18dB Hi-pass Crossover: 50Hz - 120Hz
            Variable 18dB Low-pass Crossover: 50Hz To 120Hz
            Bass boost: 0-12dB
            Bass Boost Frequency: 40Hz-100Hz
            RCA Throughput Connections
            3-way Protection Circuitry: Thermal, Short Circuit and Overload
            Top Mount Controls with Blue Illumination
            Cooling Fan
            Chrome Z Fan Grille
            Brushed Aluminum Chassis
            BALANCED LINE INPUTS
            2 Ohm Mono - 400 x 1
            1 Ohm Mono - 560 x 1
            Height - 2 3/8"
            Width - 12 3/4"
            Depth - 15 1/8"
            and
            DUB - 1 x 800 Watts @ 4 Ohm
            4 Ohms Mono: 800W RMS x 1
            This amplifier is NOT 2 ohms or 1 ohm stable
            THD: 0.02%
            S/N Ratio: >100dB
            Bass boost: 0-12dB
            Cooling Fan
            Chrome Z Fan Grille
            Balanced line input
            Height: 2 3/8"
            Width: 12 3/4"
            Depth: 15 1/8"
            Warranty: 1 Year Onlinecarstereo.com warranty.
            for the kenwood kac-8151d i got:
            "With a maximum power rating of 1,000 watts, the KAC-8151D is perfect for powering subwoofers. Its 200 watt x 1 Class D power amp uses digital switching to amplify audio signals, for highly efficient power with far less heat. It has selectable bass boost (+6/+9/+12dB/Off) that's controllable with the included wired remote. A variable low-pass electronic crossover and a selectable infrasonic filter give you tremendous installation flexibility. Also included are a Dynamic Expander circuit, speaker level inputs, and a Quiet Turn-On circuit."
            Key Features
            * Cast Aluminum Heat Sink: with Sandblast Finish
            * Power Indicator: Blue Logo Triangle
            * Class D Operation
            * Ground Isolation Circuit
            * Quiet Turn-On
            * RCA Audio Inputs: Gold-Plated
            * RCA Line Outputs: Gold-Plated
            * Selectable Infrasonic Filter: Off/15/25Hz, 18dB per Octave
            * Speaker Connectors: Gold-Plated, Screw-Type
            * Speaker Level Input Terminals: Plug-Type
            * Variable Low-Pass Electronic Crossover: 50Hz - 200Hz, 18dB per Octave
            * Bass Boost: Off/+6/+9/+12dB (Remotely-Controllable)
            * Remote Control for Bass Boost
            Power Output
            * Maximum Output Power: 1000 Watts
            * Power Output at 2 Ohms, at 14.4V (100Hz, 0.5% THD): 400 Watts x 1
            * Power Output at 4 Ohms, at 14.4V (20Hz - 200Hz, 0.5% THD): 200 Watts x 1
            * 2-Ohm Stable
            * Copper-Shielded EE Core Transformer
            * Noise Supression Filter: Large Toroidal
            * Power Input Terminals: Gold-Plated, Large Screw-Type
            * Power MOSFET Switching Power Supply
            * Power Supply Fuse: 40A
            * Secondary Capacitors: 2 Large
            Kenwood KAC-8151d Specs
            Price & Contact: $300; 800-KENWOOD; www.kenwoodusa.com
            Operating Voltage: 14.4 Volts (11-16 Volts allowable)
            Power Output: Max Power 1000 Watts (not verified)
            Rated Power: 200 watts into 4 ohms; 400 watts into 2 ohms; 500 watts into 1 ohm
            Measured Power: 269 watts into 4 ohms; 414 watts into 2 ohms; 517 into 1 ohm
            Current Draw @ Max Power: 21.7 amps @ 4 ohms; 36.4 amps @ 2 ohms; 55.4 amps @ 1 ohm
            Amplifier Efficiency @ Max Power: 89% @ 4 ohms; 81% @ 2 ohms; 66% @ 1 ohm
              Re: which amp
              yes
              yea but it has low efficiency in 1-ohm operation at 66%
