headunit resets - FirebirdV6.com/CamaroV6.com Message Board
headunit resets
  • headunit resets
    my headunit resets everytime I get off my car. I am so tired of having to put back all of the settings, I have the power wire connected and the acc wire connected and I have tried a new ground instead of using the factory ground and it didnt seem to help.Could it be a fuse?btw its a pioneer headunit I bought from bestbuy.
    Re: headunit resets
    Your constant power source isnt hooked up correctly, therefor its not saving the settings you input.
    Did you hard wire this? or use a wire harness, I dont see how you could have messed it up if you used a wiring harness.
    *Matt
      Re: headunit resets
      There should be 2 power wires n the back of your head-unit. Most commonly, they are red and yellow. The red wire is the one you hook up to your acc, and the yellow one is the one you hook up to a constant source of power. But they are not always red and yellow, so check your owners manual or online at the manufacturers website.
      Representin' Team Red In The North
      Red '96 Pontiac Firebird "Smokeshow" 3800, M5, Far From Stock!!
      Black/Red '89 Jeep Cherokee "Tigerclaw" Chev 327, Turbo 400... Stock What??
      Black/Red '02 Honda CBR 954RR Fireblade
        Re: headunit resets
        ya if you hooked up the harness color for color you shouldn't have any problems with it
          Re: headunit resets
          I do have a harness for it and both the power and acc wire are connected
            Re: headunit resets
            Yellow to yellow
            Red to red?
            if so then you shouldnt have a problem, check the wire make sure you have constant 12 volts on at least one of them with a DMM if you own one.
            If all is good there u have a problem with the radio.
            *Matt
