Sub enclosures options - FirebirdV6.com/CamaroV6.com Message Board
  • Sub enclosures options
    i was looking at one of the stealth enclosures but they only fit a 10. i have a 12 that one of my friends is no longer using and i was wondering where i could put a 12 without taking up my whole trunk? what have you guys done?
    -Y87
    Lid,K&N Filter,PaceSetter Headers,Magnaflow Cat 2.5in S-pipe,Flomaster :(,3.42 LSD
    Re: Sub enclosures options
    you are pretty limited on where you can put that twelve where it wont take up your trunk room. plus those stealth boxes are pretty dang nice and you wont lose any space.
      i made a custom box for a 1 15 inch sub and i got access on one half of the side of the trunk:D :D :D
        mine serves alot of options. it holds my sub my amp. it has a section for storage and it hides my nitrous. i did custom build it.
        WAWA-A-HOLIC
          im almost positive a 12 inch sub wont fit it the gap..you have to go with 10 if you want the stealth
            Wow thats awesome!
            i know that i was thinking of making a box that took up part of the left side of the trunk.
            -Y87
              got any pics of it?
              -Y87
                hey do you have any pics of that set up from a distance?
                  When I get home tonight, I will take a picture of the box I just got done building over the weekend. It's not carpeted (yet) but it goes on that "shelf" that sits over the back axle behind the back seat. It allows the trunk to be fully utilized, and should fit at least 2 12s, if not 2 15s. I'll have to measure it, I don't remember if there is enough surface area on the top of it for 15s.
                  It allows for up to 7.25" mounting depth subs without using rings, it is a sealed box design made from 3/4" MDF, seams are all glued and screwed. I plan on testing it tonight with one, and then 2 10" subs (real cheapies that I am carrying over from my old car). I also have a nice Kicker CVR10 in my Fiero that I'm going to "borrow" for testing.
                  I'll measure it again tonight also and calculate it's volume.
                    Who needs access to half a trunk? If you're going to go.... go all the way.
                    Yep. Those are 15"s
                    EDIT: If you really only want one 12" and want it to look good.... I'd build my own stealth box. Lose the spare tire to make up for the weight increase from the sub/box.
                    http://www.fbodyaudio.com/articlevie...tealthbox.tech
                    Red 96' A4 Firebird
                    Audio Audio and Autotek
                    Check it out here!
