Ok so I recently got in an accident and ever since my subs havent worked. I've check all fuses and all connections. Everything is fine but for some reason my amp is not power up. Any help? Im not sure how to check if the amp is fried or not Any suggestions would be great thanks
Need Help no power!!
Re: Need Help no power!!
Disconnect your subs from the amp all together. Remove them from the equation. Do you have a multimeter? Or atleast a test light? If so, test right at the amp terminals for +12V power. Now flip your radio on and insure that you now have +12V at the remote turn-on terminal as well. If you do, and the amp still refuses to turn on... something's busted. Simple as that.
Originally posted by 96firebird311Disconnect your subs from the amp all together. Remove them from the equation. Do you have a multimeter? Or atleast a test light? If so, test right at the amp terminals for +12V power. Now flip your radio on and insure that you now have +12V at the remote turn-on terminal as well. If you do, and the amp still refuses to turn on... something's busted. Simple as that.
