hidding wire - FirebirdV6.com/CamaroV6.com Message Board
hidding wire
  • hidding wire
    ok so i put in a sub and amp in my trunk i did fine hiding all my wires tell i hooked them up to the amp and sub can any one give me some advice on how to hide them and if u can post pics of your system up please. thanks guys
    Re: hidding wire
    here is mine just use what you got and work with it under carpet any way you can make your friends think like the pros did it that was my goal,i think,i did a good job what do ya think?
    http://forum.camarov6.com/showthread.php?t=84262&page=2
      Re: hidding wire
      slit the carpet right where the wires mount to the amp, and run the wires under the carpet until the slit
      just pull em thru the carpet 2 inches or so and connect them to the amp
      if its still obvious, wrap the wires nicely with electrical tape so they arent as obvious, or get wire loom.
      *Matt
        Re: hidding wire
        Figure out where you're going to mount your amp, and then slit the carpet abit further under where the amp will sit. Then bring the wires through the carpet, hook them to the amp, and pull them tight. This way they'll all be pulled right under the amp and seem to disappear, and the only visible part of it will be what ever amount is necessary to hook it up to the amp.
        ~97 3.8L V6 Camaro~
        A few things
        Only Member of Team Hooker?!?
          Re: hidding wire
          Except if your running anything bigger than a 12 ga. power wire or ground wire your amp wont sit right...
          and pinching the RCA's, not a good idea.
          *Matt
            Re: hidding wire
            Then you put spacers on the feet of the amps. I'm running a 6AWG power, and hid it right under my RF amp like that just fine. It depends on the amp make. If you don't like that, then build a small box like out of wood and carpet it the same color as your carpet. Run the wires under the original carpet as close to the amp as you can, and then cover it up with the wodden box. Or just do a custom amp enclosure that'll hide everything.
            ~97 3.8L V6 Camaro~
            A few things
              Re: hidding wire
              http://www.cardomain.com/member_page...509_3_full.jpg
              has any one bulit one like that if so do you no the demnsions?
                Re: hidding wire
                here's what my set up looks like, installed it all myself :)
                  Re: hidding wire
                  Here is mine... works for me.
                  <b><i>Don\'t Ever Judge Me</i></b><br /><a href=\"http://www.cardomain.com/id/earnhardt132000\" target=\"_blank\">\'96 Firebird Y87 3.8L V6 5spd</a><br />--No mods as of yet, shoot me some ideas if ya want.<br />178,000 miles and counting
                    Re: hidding wire
                    Meatyshells do u have the dimensions for the box??
                      Re: hidding wire
                      It's a subthump amp rack.
                      You can buy em online like that
                      *Matt
                        Re: hidding wire
                        www.subthump.com
