JL Audio W7 12 - FirebirdV6.com/CamaroV6.com Message Board
JL Audio W7 12
  • JL Audio W7 12
    is this a good choice for the hatch of an f body? i got a really good deal on one and am not sure if i want to get it. all my friends say it is really good sub woofer, but i dont know.
    96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
    Re: JL Audio W7 12
    Dimensions:
    Frame Diameter: 12.5 in. (318 mm)
    Mounting Hole Diameter: 10.5 in. (267 mm)
    Mounting Depth: 9.5 in. (241 mm)
    Overall Depth: 11.25 in. (286 mm)
    Magnet Diameter: 7.5 in. (191 mm)
    Pole Vent Clearance: 0.75 in. (19 mm)
    Displacement: 0.14 cu. ft. (3.03 ltrs)
    Enclosure Recommendations:
    Sealed Range: 1.25 - 1.625 cu. ft. (35.4 - 46.02 ltrs.)
    Recommended Sealed Volume: 1.375 cu. ft. (38.94 ltrs.)
    Fc: 44.7 Hz
    F3: 40.4 Hz
    Qtc: 0.792
    Ported Range: 1.5 - 2.25 cu. ft. (42.5 - 63.7 ltrs.)
    Recommended Ported Volume: 1.75 cu. ft. (49.56 ltrs)
    Recommended Tuning: 32 Hz
    Port Type: ?Slot? ports are recommended. See Data Sheet for detailed info.
      Re: JL Audio W7 12
      I think you know as well as we do that the W7 is regarded as one of the all-around "best" subwoofers made today.
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        Re: JL Audio W7 12
        i am getting it for pretty much free. well i am trading a lt1 long block for it.
          Re: JL Audio W7 12
          Hell yea.. way to go!
          you should be very impressed with that sub
          *Matt
            Re: JL Audio W7 12
            so there is enough air space and what not to use it.
              Re: JL Audio W7 12
              You haven't told us anything about the enclosure you plan on using. But if you're asking if there enough space under the hatch of an F-body in general..... easily.
              Red 96' A4 Firebird
              Check it out here!
                Re: JL Audio W7 12
                thats would be what i dont know, currently i have a diamond audio 12 that cam with a box in the trunk. it is just kinda loosely laid in there with the amp. i dont know anything about this stuff but my friends do.
                  Re: JL Audio W7 12
                  if you can afford to buy an amp to power it lol
                    Re: JL Audio W7 12
                    actually a friend of mine already has an amp for me. some kinda kicker amp that was severely under rated(rated at 400 watt, really puts out about 1300). so i might be able to win a few audio competitions.
                      Re: JL Audio W7 12
                      What amp is this?
                      *Matt
                        Re: JL Audio W7 12
                        --^ the fake kind.... w7 are awesome had one and it got the job done...
                          Re: JL Audio W7 12
                          it is a kicker of some sort, something they dont make anymore. maybe a little exageration on the rating to actual, but from what i have heard it was only available for a short time then taken off the market and relabeled to it true rating . i am gonna definately get the w7 and i am gonna "borrow" the kicker amp. so i will take pics and maybe a video with sound too, when i get it all in there
                            Re: JL Audio W7 12
                            id rather have the diamonds over JL
                              Re: JL Audio W7 12
                              i could actually do two diamond 12's, but i am getting the w7 for a motor i wasnt gonna use and paid nothing for anyway. so if i dont like it then i wouldnt be out anything anyway.
