infinity kappa perfect 6.1's (x4) *components...........4 ohm?
the amplifier that powers the speakers is a 400 watt rockford fosgate, 4 channel amp... 4 ohm
the other amp is a 500w rockford fosgate that is for teh subwoofer...
10 inch rockford fosgate p3 400w sub
the shop that has been doing all the warranty work says these are matched etc and there shouldnt be any issues...(the speakers peak power is 400w??is that per speaker or for each set of the components???)
last time i took it in i had them install a capacitor despite them saying i shouldnt need it and my headlights no longer dim+ this amplifier is fairing alot better than the last two,it takes longer for the amplifier to cut out and i can play it louder... (lol,im glad the warranty is for 5 yrs)
ive had this problem since i had the system installed,when playing at loud volumes the speakers will cut out (amplifier turns off,i believe it has built in protection or something) and at this point i can just turn volume down to half or below and speakers/amp are on again..
*until at which point the amplifier dies (im on my 3rd amplifier in 3 months and i will be going in for another replacement soon if i or they dont find the problem...
(subwoofer and the amplifier powering the subwoofer do not cut out during this, it keeps playing and i havent had to replace the amplifier that is hooked up to sub even once)
i have a few ideas:::
maybe the speakers are wanting more power than the amplifier can put out???
maybe the alternator isnt supplying enough power and the amplifier is the victim of this??? is it possible for the alternator to be still working but not working well enough?
i dont believe im abusing the system, there is zero distortion in speakers(never has been,speakers could prolly go twice as loud as they currently do)...from what i have read in reviews you should be able to hear this system from a block or two away and ive never been able to turn it anywhere near this loud imo(they have the volume level set low on amplifier i think,ive not messed with it)...in all reality i dont think the speakers are even broken in yet because i dont use the car that much.
the system isnt over 1k watts...it isnt that loud and i should be able to turn it up as loud as i do (i can still hear myself talk when near max volume,for how much i paid i should be able to give myself a headache/earache on demand)...i need a fix.
