can someone draw me a quick diagram?? - FirebirdV6.com/CamaroV6.com Message Board
  • can someone draw me a quick diagram??
    ok i have a RF 10" P3 its the 4ohm model and i have a kenwood mono 1000 watt amp to power it....its 500rms at 2ohm and 300rms at 4ohm my question is how should my wiring look for this? can someone draw me a diagram...id like to get the most power out of my sub as possible without blowing it. its max is 800 so if someone could draw a nice wiring diagram on paint or something id appriciate it.....also how much power is capable of getting to this sub?
    Re: can someone draw me a quick diagram??
    The RF homepage is down right now.... can't find anything out about the speak. Maybe one of the guys that owns it can advise.
    FirebirdV6.com/CamaroV6.com Administrator
    Stupid is rewarded with the ban button.
    Official Avatar Nazi according to Meatyshells :D
      here is some info but im not sure if its what you will need or not
      10" subwoofer with dual 4-ohm voice coils
      fiber cone reinforced with Kevlar with poly-ether-ester surround
      "Venturi-effect" design for maximum cooling of motor structure
      power range: 50-400 watts RMS (200 watts per voice coil)
      peak power handling: 800 watts
      frequency response: 29-250 Hz
      sensitivity: 83 dB
      top-mount depth: 6-1/4"
      sealed box volume: 0.5-0.75 cubic feet
      ported box volume: 1.4 cubic feet
        This will cause a final impedance of 2-ohms, so you are going to be pushing the sub with 500WRMS. Since it is rated at 400WRMS, be careful with your amp settings.
        <b><i>Don\'t Ever Judge Me</i></b><br /><a href=\"http://www.cardomain.com/id/earnhardt132000\" target=\"_blank\">\'96 Firebird Y87 3.8L V6 5spd</a><br />--No mods as of yet, shoot me some ideas if ya want.<br />178,000 miles and counting
          The above drawing is correct. Surely you're using a simple enclosure and that sub can handle anything that amp can do. Have fun.:)
          Red 96' A4 Firebird
          Audio Audio and Autotek
          Check it out here!
            ok that was the way i had planned to hook it up but didnt know for sure if that was correct......one more question could someone find on for a amp to run 2 ohm to two 10" p2's that are the 2 ohm model????
              Rockford produces the P2 in both single and dual voice coil design. We need to know if the sub is DUAL 2 ohm or SINGLE 2 ohm. Look at the sub. How many connections for + and - does it have? One pair = single voice coil. Two pair = dual voice coil.
              Red 96' A4 Firebird
              Check it out here!
                my bad its they are dual voice coils
                  http://cgi.ebay.com/NEW-BXI-1606D-Hi...QQcmdZViewItem
                  That amp will smoke the **** out of them. But why not pay an extra 20 bucks for the extra power? You know the subs will be upgraded within 6 months. lol Get the dual 4 ohm when upgrading.
                  Red 96' A4 Firebird
                  Check it out here!
