Trunk rattle - FirebirdV6.com/CamaroV6.com Message Board
Trunk rattle
  • Trunk rattle
    So I put in a sub system (pics later today) and my trunk rattles a lot. It is only audible outside the car. What would you guys recommend for sound deadening material? A friend of mine swears by dynamat, but I'm wondering about alternatives; dynamat is a bit pricey around here.
    Sound sys:
    Pioneer head unit with preamp out
    2x Kenwood 10" Parallel wireing for 8+8 = 4ohm
    Kenwood 2ch 350w RMS amp bridged
    Sealed and separated box about 1cf per sub
    4ga wireing to batt and ground (inline fuse 1' from batt)
    I've been playing variations of the THX Bass Test song, and it hits hard from 20-25hz :) sealed box ftw. I asked my bro to come over two days ago and tricked him into getting into my car (can't see the amp/subs cause of limo tint) and played Jucy - Biggie Smalls. For those that don't know: the song has no bass during the intro, then hits extremely hard. His eyes bugged out.
    Re: Trunk rattle
    i would also like to know what is a good material , plus where/how to install it.
      Re: Trunk rattle
      As far as installing, my friend says to crank the bass and push on areas that are rattling. When the rattling stops you found the spot. Usually you can figure out how to deaden it once it's found. I just don't know what to use because I'm only getting one (biased) opinion.
        Re: Trunk rattle
        GinsuGuy is spot on. Find the offending pieces then wedge something in there to prevent the vibrations. If you're looking to lower the amount of outside noise in the vehicle...
        http://www.sounddeadenershowdown.com/
        /thread
        Red 96' A4 Firebird
        Audio Audio and Autotek
        Check it out here!
          Re: Trunk rattle
          /thread
          lol u know what else we could do? and i do this all the time.... just turn up the system so loud that u can't hear any vibrations =)
            Re: Trunk rattle
            Heh well I've been doing that inadvertently. :D
            I found 2 spray cans (armor-all and windshield de-icer) that were rattling a lot, but now it seems to be the rear hatch and spoiler.
              Re: Trunk rattle
              Update: I lengthened the two rubber screw things in the trunk (by unscrewing them a little) and the rattle has gone down even more.
                Re: Trunk rattle
                Let me know if you guys find a product that works.
                My set up im getting will more then likely do the same thing.
                And i will be in the market for something like this.
                Mods:
                Slp Dual Cold Air Intake
                Racing Stripes
                Flowmaster Exhaust [2.5 Pipes, Flowmaster 80 Series Muffler]
                Camaro Fill Ins
                Black Outs
                Tint
                  Re: Trunk rattle
                  Did nobody view my link?!?!!??!
                  Red 96' A4 Firebird
                  Check it out here!
                    Re: Trunk rattle
                    yeah i did view your link thanks lots of info
                      Re: Trunk rattle
                      make sure you check that your spare and jack arent rattling
                        Re: Trunk rattle
                        Those went bye-bye a long time ago :D
                        I still don't know what I'm going to do, it seems like the spoiler/hatch are making the noise. Maybe I'll fill them both with foam.
                          Re: Trunk rattle
                          Go to Home Depot and get a gallon of asphalt roofing mastic and paint it on thick.
                          Lounge Moderator
                          • 187shark
                            by 187shark
