sub cuts out - FirebirdV6.com/CamaroV6.com Message Board
sub cuts out
  • #31
    Re: sub cuts out
    Try those songs I linked, it might be that whatever you are listening to doesn't have much bass. The ones at the bottom of the page are more fun to listen to, but the ones at the top are very precise.
    If it can play those louder than you can stand, you're all set and just need better music. :D It looks like your box is sealed so it should do very well with the low frequencies (20-30hz.)
    This one is crazy give it a try.
    • #32
      Re: sub cuts out
      ok guys. is this enough for my problem.
      1-Farad Capacitor
      Delivers improved sound quality with cleaner mids and highs
      Low ESR (Equivalent Series Resistance)
      16V to 20V peak
      Solid-brass top reduces stripping; platinum plated
      WAWA-A-HOLIC
      • #33
        Re: sub cuts out
        I don't think you would need more than 1 farad, but you're sure a cap is your prob?
        • #34
          Re: sub cuts out
          i've tryed what everyone else has told me. and i the only problem is the cutting out under high out put, and the lights dimming. so it sounds like that is the problem. that is what i'm going to buy it from a local place. and if it's not the problem i can always return it.
          WAWA-A-HOLIC
          • #35
            Re: sub cuts out
            A large advantage of buying from local retailers.:tup:
            Red 96' A4 Firebird
            Audio Audio and Autotek
            Check it out here!
            • #36
              Re: sub cuts out
              When your subs hit, does your voltage meter bounce a lot? If it does then get a cap, if not then don't bother.
              • #37
                Re: sub cuts out
                i have the same problem with my system except it is both the speakers and sub that cut out lol.. only under near max volume...sux
                • #38
                  Re: sub cuts out
                  I had 2 of the Pioneer subs like that that were 12's and drove them with a Kenwood 800 which is near identical to that Pioneer and never experienced it cutting out unless it was from low voltage. I didn't run a cap, but I had mad headlight dims from it. It sounds like a bad connection to me, somewhere. OR possibly the outputs from head unit need to be isolated from the amp, had that before and it caused a mind numbing alternator whine.
                  The cap may help with the voltage problem, but with good connections and large enough wire size you shouldn't need it. I used 4 ga. wire.
                  Good Luck,
                  and let us know!
                  2002 Navy Blue Metallic Blue Firebird A4
                  Pure stock (Hey, just bought it 11/07)
