Mtx thunder 600w stealth? - FirebirdV6.com/CamaroV6.com Message Board
  • Mtx thunder 600w stealth?
    Okay just bought these now for my audio system today. What do you guys think about the mtx thunder 600w for the stealth box. Will I be impressed with this. Good power of bass???? How hard is the install if I was to install these myself?
    http://cgi.ebay.com/ebaymotors/ws/eB...TODAY.m238.lVI
    http://cgi.ebay.com/ws/eBayISAPI.dll...TODAY.m238.lVI
    Re: Mtx thunder 600w stealth?
    Page not responding on all 3 for me
      Fixed......:banana:
        Mise well order the wiring while you're at it.
        http://www.knukonceptz.com/productDe...?prodID=KLM-K8
        Have an aftermarket headunit?
        Red 96' A4 Firebird
        Audio Audio and Autotek
        Check it out here!
          Oh I had already ordered the wiring set. Nope don't have aftermarket stereo!! I like the stock one:naughty: !!
            Then you will also need a line output converter. This will take speaker lead inputs and turn them into RCA connections that your amp will accept.
            Red 96' A4 Firebird
            Check it out here!
              Would this work o.k.??
              http://cgi.ebay.com/NEW-RCA-Car-Line...QQcmdZViewItem
              Or this 1?
              http://cgi.ebay.com/Stinger-High-Pow...QQcmdZViewItem
                is there going to be a problem considering he's got a 600w sub but only a 500watt amp? or does that not matter?
                  The sub and amp are both rated at 300 watts rms, the 600 and 500 watt numbers are just peak power which are rarely reached.
                  1994 Pontiac Firebird M5<br />Flowmaster 80 Series/dual pipes<br />Magnaflow High Flow Cat<br />eBay two piece intake<br /> <a href=\"http://www.cardomain.com/ride/2112560\" target=\"_blank\">http://www.cardomain.com/ride/2112560</a>
                    neato, so you dont want your amp rms above your sub rms?? or is it the other way around?
                      RMS power is only reached if your listening at high volume levels anyway, but you don't want your amps RMS rating to be above your subs RMS rating. That's what leads to your sub getting blown. You can run a 1500W rms sub on a 100W rms amp, and never have to worry about a thing. You just wouldn't be pushing the sub to it's potential.
                      I wouldn't have gone with the MTX sub, and I don't know much about bazooka, but I know what the stealth enclosures are capable of. What are you looking for out of the setup? btw, the install is easy, just a few wires and screws.
                      1996 Chevrolet Camaro
                      1995 Buick Park Avenue Ultra
                      --Appearance Moderator--
                        gotcha, thanx schlotzk
                          Whats bad about the mtx sub???
                            Out of personal preference, I just stay away from MTX altogether. My dad has an MTX amp powering an MTX sub and it sounds bad. It could be the amp, it could be the sub, or it could be the box, but I still stay away after hearing it.
                            MTX is known to be a decent brand, nothing special, but not terrible. I'm sure your setup will be decent, it's just not what I would have chosen.
                              Oh ok...lol.. I just wanted some bass not too much but just some to wake up my car audio system...
