volume problem - FirebirdV6.com/CamaroV6.com Message Board
volume problem
  • volume problem
    the volume knob on my head unit is broken, it dosen't let me change the volume, it changes when it wants to. is there a problem with the head unit or is it a easy fix. can someone help me out.
    Re: volume problem
    Not worth your time/money. Even if you could fix the knob, the stock headunits drop like flies. Spend the $150 in a new headunit and install parts. Look for open box deals at Circuit City. And hell.... if you're serious about going aftermarket, let me know. I have an antenna adapter lying around here you can have for the price of postage. (Prolly 50 cents)
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      Re: volume problem
      what is the antenna adapter for?
        Re: volume problem
        Pay no attention to the yellow words. The plug on the left is a General Motors antenna wire. This comes from the antenna mast and plugs into the stock radio to allow FM/AM reception. Unfortunately, EVERY aftermarket headunit manufacturer uses the plug on the right. So you need an adapter to allow your stock antenna wire to plug into your new aftermarket headunit. Circuit City charges $18? for them. I'm sure most any other install shop would be about the same price.
        Red 96' A4 Firebird
        Check it out here!
          Re: volume problem
          o.k thanks for the advice i'll look into getting a new headunit
            Re: volume problem
            for the moment is there any way to fix the volume problem
              Re: volume problem
              There's not really much you can do. Give the knob a gentle pull and see if it pops off. Maybe try cleaning around that whole area. But honestly, there's really no chance of that helping seeing as how volume changes by itself. (Meaning the knob doesn't even move) lol Sorry.
              Red 96' A4 Firebird
              Check it out here!
                Re: volume problem
                if the actual knob is broke why now glue it, thats what i did with my ac knob and no problems....all i can say
                  Re: volume problem
                  do you have steering wheel controls ?
                  1997 Camaro LS1 RS
                  1994 Camaro - Sold
                  1999 Trans am Vert - Sold
                  A Few Mods....
                    Re: volume problem
                    no i dont have steering wheel controls
                      Re: volume problem
                      The knob is physically broken!? I assumed it was just faulty. Especially because he said the volume changes by itself. Krazy Glue!
                      Red 96' A4 Firebird
                      Check it out here!
                        Re: volume problem
                        the knob is not physically broken, i try to change the volume and when i turn the knob it only changes the volume sometimes, thats what i mean
                          Re: volume problem
                          Ok that's what I thought. Oh so common on anything with a "knob" to change volume. Both in the car audio world and home audio world. You should be able to snag a brand new Pioneer of Ebay for as little as $100. Then roughly $40 in parts and 15 minutes of your time.
                          Red 96' A4 Firebird
                          Check it out here!
                            Re: volume problem
                            I know what you are talking about, my first fbody, 94 firebird did the same thing.
                            I fiddled with it for quite a while and nothing happened. sometimes you'd just be driving with the radio quite and it would turn it up full blast on its on, sometimes...
                            but the knob barely worked like your saying.
                            If you dont really care about aftermarket car audio stuff, you could just buy a used (stock) headunit on ebay for alot cheaper, just swap them out.
                            *Matt
                              Re: volume problem
                              i already asked this in another thread but will a camaro headunit work on a firebird with no modifications to it?
