better to run 2 ohm or 4 ohm - FirebirdV6.com/CamaroV6.com Message Board
  • better to run 2 ohm or 4 ohm
    What sounds better running 2 ohms on a type r or 4ohms on a type r. In the stealth box.
    Re: better to run 2 ohm or 4 ohm
    We need to know exactly what amp you are using. A model number would be great.
    Odds are..... if you are using a single channel amp, you will want the dual 4 ohm version of Type-R. Parallel the coils to give you a 2 ohm load. Most possible power out of the amp. If you are using a two-channel amp, you will want the dual 2 ohm version of Type-R. Run the coils in series for a 4 ohm load and bridge the amp.
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      there's not a "better" voice coil to buy, it depends on the application and what load (ohms) you want to push from your amplifier
      2000 Camaro 3800 A4
