factory amp Q - FirebirdV6.com/CamaroV6.com Message Board
factory amp Q
  • factory amp Q
    OK my factory system has all the signs of being a monsoon except there is no amp by the spare tire. so were would the amp be? or the cross over for the factory subs if there is one. this hole monsoon or not thing has got me going crazy, and sorry if this is a repeat Q. i am running an after market HU.
    Re: factory amp Q
    if you're running a aftermarket HU, then the amp was probably removed due to the fact it can't be used with an aftermarket HU.
    ~97 3.8L V6 Camaro~
    A few things
    Only Member of Team Hooker?!?
      Re: factory amp Q
      yeah but there isn't even the wiring harness for the amp so did they take it all out? the HU is wired in with the adapter and all, according to the receipt i found in the glove box the HU was installed at Best Buy.
        Re: factory amp Q
        Sorry bro but,:twak:. The entire Monsoon system can in fact be used with any aftermarket headunit without any modifications. Which also makes me ask.... what "adapter" did Best Buy use?
        Second, is it possible you have the Bose system vice Monsoon?
        Third, here's some info from our FAQ thread:
        Monsoon System:
        Indash CD-Player or Cassette Deck, 10-speakers (6-3/4" mid and separate tweeter located in each door, 6-3/4" dual voice coil subwoofer located on the sides where the rear passengers sit, 4" mids along with tweeters located wayy back in the hatch area.) and a factory Amp which is located next to where the spare tire is (the amp mounts on a plastic plate and tucks inside the rear fender area, you have to remove the spare tire to see it).
        Regular Stock System:
        Indash CD-Player or Cassette Deck and 4 speakers. (Two 6-3/4" speakers up front, one in each door... and two 6-3/4" speakers in back where the rear passengers sit)
        There's also anoter system called the "Entertainment System" which is exactly the same as the Monsoon (same layout, amp, speakers, etc.); however, it just doesn't say monsoon. Open your drivers door and look on the side of the door for the RPO codes (3-digit codes). See if you have any of these:
        UL0 AM/FM Cassette ETR 200 Watt Monsoon Sound System w/cassette
        UN0 AM/FM Cassette ETR 200 Watt Monsoon Sound System w/CD player
        UN6 Radio, AM/FM stereo, Seek/Scan, Auto Reverse Music Search Cassette, Clock, ETR
        UQ0 Speaker System 4, Dual Front Door Mounted, Standard Range Quarter/Shelf
        UU8 Radio, AM/FM Stereo, Seek/Scan, Auto Reverse Music Search Cassette, HPS, Clock, ETR
        U1A CD radio, 10 speaker
        U1C Radio, AM/FM Stereo, Seek/scan, Compact Disc, Clock, ETR
        U1S 12 Disc Compact Disc Changer
        U1T Radio, AM/FM Stereo, Seek/Scan, Compact Disc, HPS, Clock, ETR
        U18 Speedometer Instrument Kilometers
        U19 Speedometer Instrument, Kilometers and Miles, Kilometer Odometer
        U62 Speaker system 4, Dual Coax Front, Dual Coaxial Package shelf
        U65 Speaker system 5, Dual Front Door Mtd, Dual Ext. Range Panel, Single Rear Compartment
        U73 Antenna, Fixed
        U75 Antenna, Power
        UT6 AM/FM stereo, seek/scan, auto rev
        UW2 speaker system, 10, quad front door mounted, dual rear sail panel
        V73 vehicle statement, US/CANADA
        VG8 Label, Vehicle, Notice to Buyer
        VH5 Plate, Vehicle Information
        VK3 License Plate, Front Mount Package
        VM3 label information consumer, contains bumper impact standared
        VP6 Noise Control
        WS6 Performance Package - Formula/Trans Am
        WS9 model conversion, FORMULA
        WU8 SS Performance Package/Appearance Package - Camaro
        W51 Entertainment system - Radio, AM/FM-stereo, seek/scan, cassette, 4 Speaker system · Standard Range
        W52 Entertainment System - Radio, AM/FM stereo, Cassette, Equalizer, 4 Speaker system - Coaxial
        W53 Entertainment System - Radio, AM/FM Stereo, Compact Disc, Equalizer 4 Speaker System - Coaxial
        W54 Entertainment System - Radio, AM/FM Stereo, Cassette, Equalizer, 10 Speaker System, Amplifier
        W55 Entertainment System - Radio, AM/FM Stereo, Compact Disc, Equalizer 10 Speaker System, Amplifier
        W57 Entertainment system - Radio, AM/FM stereo, Cassette, Equalizer, 4 Speaker system - Coaxial
        W58 Entertainment system - Radio, AM/FM Stereo, Compact Disc, Equalizer, 4 Speaker system - Coaxial
        W59 Entertainment system - Radio, AM/FM Stereo, Cassette, Equalizer, 6 Speaker System, Dual Front Door Tweeters/Woofers, Extended Range Shelf
        W66 Merchandised Package - Formula
        W73 Entertainment system - Radio, AM/FM Stereo, Compact Disc, Equalizer, 6 Speaker system, Dual Front Door Tweeters/Woofers, Extended Range Shelf
        Red 96' A4 Firebird
        Audio Audio and Autotek
        Check it out here!
          Re: factory amp Q
          I thought the Monsoon system ran all their stuff at 2Ohms or something, so you could use any HU, but the speakers will get more then the rated power since they're rated at 4Ohms, but are drawing at 2?
          And my dad has that U62 package....what's the "Dual Coaxial Package Shelf?"
          ~97 3.8L V6 Camaro~
          A few things
            Re: factory amp Q
            I have no clue what all those packages really mean. I had no Monsoon but 4 ohm coaxils up front and 10 ohm woofers in the sail panels in my 96 bird. No hatch speakers. Kinda weird. Whatever. lol
            And the headunit does not care what impedance the speakers are. That's the amplifier's job. Yes the headunit does output a little more power into the factory amp, which thereby outputs a little more power to the speakers, but the difference is not enormous. I've done a million of them. It's not like adding a headunit in most other upgraded factory systems. I've done other cars where everything seems to connect right up, and then you turn it on and can't even listen to it at volume setting 5.... lol Then if it was a Sony that you installed, they beep every gosh darn time you push a button and are independent from the volume knob. *BEEP* *BEEP* *BEEP* *BEEP* At ear piecing volumes. LOL
            Red 96' A4 Firebird
            Check it out here!
              Re: factory amp Q
              i will check the code, they used the pice to atach the HU to the factory wiring. i have all the speacers but no amp, so i dont know.
                Re: factory amp Q
                U75 Antenna, Power
                these are the codes i have.
                  Re: factory amp Q
                  ok well now we know what i have, but were would the cross over be for the factory subs?
