what are some good stealth amp locations, with nice air flow. Some one posted there stealth instal inside the sail panel next to the spair tire. I have 2 amps and i want them hidden! where should they gO
Stealth amp locations
Re: Stealth amp locations
Well, I was going to suggest getting one amp with a 4.1 channel type set up. 4 channels for speakers and one channel for sub. This is if you want to make it easy, then you can just mount it inside the left or right side in the hatch. You could also make a custom amp rack and just put in on top under the glass and make it so you cant see through it or anything. If you want to keep both amps there is the easy route by getting the amp rack that goes on the back of the hatch but its easily see-able when you open the hatch. I say get creative and think of using those spaces in the corner or building the amp rack under the glass. if you want the two amps you could put one on each side and make a wall for the drivers side one so its not wide open. this will cause you to get rid of your spare tire. Pretty much all the things i mentioned are in threads somewhere. Im too lazy to look tho, sorry.
any other suggestions?
Not sure if i wanna run the M650 or M500 and the F250 or F300
anybody have one or more of those amps?
heres the Dimensions of all 4 amps tho
M650
Heat Sink (WxHxD) in: 11-1/64" x 9-31/64" x 2-23/64"
Foot Print (WxHxD) in: 12-7/8" x 9-31/64" x 2-23/64"
M500
Heat Sink (WxHxD) in: 8-17/64'' x 2-23/64'' x 9-33/64''
Foot Print (WxHxD) in: 10-5/8'' x 2-23/64'' x 9-33/64''
F250
Heat Sink (WxHxD) in: 9-9/64'' x 2-23/64'' x 9-27/32''
Foot Print (WxHxD) in: 10-15/16'' x 2-23/64'' x 9-27/32''
F300
If i go with the M500 and F300 i could possibly mount them on the passanger side where a stealth box would fit, no need for a spare tire!
