Speakers rattle - FirebirdV6.com/CamaroV6.com Message Board
Speakers rattle
  • Speakers rattle
    So I put in some new Infinity Reference speakers in the sail panels, but when the bass hits they rattle. What can I do to keep them from doing that?
    1996 Silver Camaro RS, A4, K&N CAI, Flowtech exhaust, !MAF screen.
    http://www.fquick.com/96silverbullet
    Re: Speakers rattle
    turn down the bass. What do you have powering them? Do you have "loudness" on? Is it the speaker or the surrounding rattling?
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
      Re: Speakers rattle
      I had a shop put mine in mostly because i was lazy and didnt want to add amps to my stock radio...but anyways, they didnt screw them in very good, and it was difficult trying to get the screws in good after i took them out to fix them. (yea, 400 for an install and i have to fix it.) You just gotta make sure they are screwed in there as best as you can. If im wrong im going to sound like an idiot but i think the stock speakers are a little larger than 6 1/2 if thats what you added. goodluck.
        Re: Speakers rattle
        They are indeed 6 3/4", but it makes no difference. Use a little effort and a completely solid mount is easily possible with any 6 1/2" speaker. Make new holes with self tapping screws.
        Try removing the plastic covers over the rear speakers and roll with that for a minute. See if they are what is causing the rattling.
        Red 96' A4 Firebird
        Audio Audio and Autotek
        Check it out here!
          Re: Speakers rattle
          Someone should make a write up of how to make a mount for it if they have done it. A lot of people will probably benefit from it.
            Re: Speakers rattle
            That ended up being it. I took them back out and used some larger screws that fit the holes I drilled a little bit better and it sounds a 100 times better. Thanks guys.
              Re: Speakers rattle
              no problem
