which amp? - FirebirdV6.com/CamaroV6.com Message Board
which amp?
  • which amp?
    I recently picked up a 250 watt (500 max) rockford fosgate 10 inch P2 sub (P210D4). It's a 4 Ohm, dual voice coil. I'm going with the single sub and I'll be mounting it in my stealth box. What do you guys like to use for an amp taking into consideration cost and quality? Give me a brand and model if possible. I don't need anything fancy, as it's just to power the sub, not my speakers.
    Re: which amp?
    http://cgi.ebay.com/KICKER-ZX300-1-S...QQcmdZViewItem
    How much you got to spend?
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      Re: which amp?
      ^I don't want bargain basement cheap...I'm assuming this is only 57 bucks for a reason? I've currently got a Bazooka amp which I think is the reason my last sub blew, so I'm going for better quality this time.
        Re: which amp?
        Looks like that amp is coming remanufactured from kicker, not new, not blown up.
        Also, it's only 300 watts so its not a very expensive amp to start off.
        Id say you'd be safe buying that amp $57 buy it now + $30 shipping :tup:
        *Matt
          Re: which amp?
          It's a factory refurb. That's why it's cheap. Kicker is a trustworthy company. If it says 300WRMS, it'll do 300WRMS+.
          If you want to spend more, just let me know. But you'll be spending $300+ for something I would call higher quality.
          Red 96' A4 Firebird
          Check it out here!
            Re: which amp?
            it does sound like a good deal, although its 50 bucks, not 30 for shipping to my door in Canada. I messaged the seller to make sure I won't be charged for brokerage fees when it gets here and if not i'll take.
            just as an aside: is it possible that my cheap bazooka amp was responsible for my old sub blowing, even though the max RMS on the amp was under what the sub could handle?
              Re: which amp?
              Stick with RF and ya can't go wrong! great sound quality, and it bumps.
              http://www.cartronixplus.com/templat...20ALL%20%3E%20
              Edit: WHOOPS they are sold out ^^^^
              try this one
              \l/
              http://cgi.ebay.com/Rockford-Fosgate...QQcmdZViewItem
                Re: which amp?
                try this one
                \l/
                Well seeing as how he has a dual 4 ohm sub.... I don't think that's a good choice at all. I wouldn't dare bridge that sucker @ 2ohms. And any of Rockford's mono amps are not cheap. AND STILL not what I would call "high quality."
                Red 96' A4 Firebird
                Check it out here!
                  Re: which amp?
                  who said anything about bridging it at 2 ohms not me. RF's are powerful amps, that routinely put out more power then what they are rated at. And as far as quality goes, sure there are better stuff out there, for a price. RF is in the sweet spot of the mid range. you get great quality for a great price. when i went to get my system i did my home work, i compared alot of brands and models, and not just on paper, haha i spent a whole week going around listening to different systems, by then end of week i thought my ears would bleed. RF is IMO one of the best brands to go with, especially when quality is a priority.
                    Re: which amp?
                    I'm out of the loop on all of this business about bridging (why I asked the question in the first place). Anyway, that seller has quite a bit of negative feedback and won't ship to Canada.
                      Re: which amp?
                      okay what specs should I be looking for? I know I should read up on this stuff but, how many channels, ohms, and watts do i need for the P2 sub?
                      how about a JBL GTO 301.1?
                      http://cgi.ebay.com/JBL-GTO-301-1-VE...QQcmdZViewItem
                        Re: which amp?
                        that a good pick, its always a good idea to have your amp rated a littlehigher wattage then your sub, so it won't stress your amp. here is a great place for some information on wiring, ohms, and the like.
                        http://www.rockfordfosgate.com/rftech/rftech.asp
                          Re: which amp?
                          ^I was always under the impression that you wanted your sub to have higher wattage than the amp so the amp couldn't blow the sub...but that's the second time I've heard your view in as many days.
                          thanks for your input guys!
                            Re: which amp?
                            So you intend him to just use one channel then? Real wise. We have the entire world to choose from, but let's buy a two-channel amp and only use one channel. Great choice.:tdown:
                            Mike, with a dual 4 ohm subwoofer, you'll want to wire both positives and negatives together to present your amplifier with a 2 ohm load. This is the rating you should be looking at during your amp search. (RMS power @ 2 ohms x 1 channel) If you don't like that seller, pick a different one. There are a million.
                            As for actual power ratings, there are A TON of other parameters that come into play to give you your final power capabilities. If you're in the same ballpark, one way or the other, you're fine.
                            Red 96' A4 Firebird
                            Check it out here!
                              Re: which amp?
                              once again you are putting words into my mouth, i never said to only use one channel. with a dual 4 ohm voice coil, and a 2-channel amp you can have one channel per voice coil @ 4 ohms each
