run 2 ohms or 4 ohms - FirebirdV6.com/CamaroV6.com Message Board
  • run 2 ohms or 4 ohms
    Have a mrp-m850 alpine amp. 1 10" type r. Should i run it at 2 or 4 ohms. Im looking for clear bass that sounds good(no rattling)
    Re: run 2 ohms or 4 ohms
    I'm assuming you have a single dual 4ohm type-r. If this is the case you won't be able to run it at 4ohm. Unless you plan on running two of those amps using one for each coil. Wire it in parallel at 2ohm.
      http://forum.camarov6.com/showthread.php?t=88616 ??
      Is the sub model number SWR-1042D or SWR-1022D?
      Edited to bold the only question that really matters in here....
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        ok basically depeneding on how hard your pushing 2ohm or 4 ohm your gunna get rattle just get dynamat to insulatae your car and you will have minium rattle but 2 ohm usally hits the best depeending on your Amp if its 2 ohm stable
          You fail :| At spelling and grammar. Power output all depends on the amp. I've had amps that are made to put out its optimal power at higher impedance ratings. With his amp, he will want to go down to 2ohm as his woofer will take up to 1,500w peak.
            "Optimal" as in "the most"? Or same power at various impedance loads? Link me to these magical amps you speak of...
            Red 96' A4 Firebird
            Check it out here!
              Any amp will attempt to create more power as you lower the load impedance. Whether-or-not the electronics of the amp can handle that is another issue all together.
              Lounge Moderator
                Well i havent bought the type r yet. Trying to decided which one to choose for sound purposes
                  There is no difference in sound quality between the two versions.
                  You will need the SWR-1042D.
                  Red 96' A4 Firebird
                  Check it out here!
                    Thats what i was trying to say, didn't word that properly.
