Monsoon amp questions. - FirebirdV6.com/CamaroV6.com Message Board
  • Monsoon amp questions.
    So I took a peak at my wheel well at lunch today, I failed to see the monsoon amp last time i had the **** apart (figured it would of been on the other side, I know failboat right?)
    I'm going to pull the monsoon amp to see if possibly for any reason its causing some of my other problems. What speakers does the monsoon amp power? Can I just unplug the harness from it and still have other components? At this point I may go ahead and run my own speaker wire and be done with it.
    Re: Monsoon amp questions.
    http://ls1tech.com/forums/showthread.php?t=612644
    That faq has been my best friend the past couple weeks while I was deciding what I wanted to do with my stereo.
    Read it over, it should answer most if not all of your questions. Goodluck!
    2000 v6 a4 Camaro
