i have a 1998 camaro with the monsoon system. i replaced the stock head unit with an alpine cda-9885. now can i stiil hook this up to the amp. when i replaced the head unit i had an extra plug that i could not use. is this what controls the amp? anybody with some advice or knowledge?
Can i still use monsoon amp and speakers with after market head unit?
Re: Can i still use monsoon amp and speakers with after market head unit?
Start tracing where the sail panel (what i assume you mean by middle) speaker wires that you put together for the back of the head unit.
Here is a page for all the wiring colors:
http://www.modifiedlife.com/car-ster...vrolet-camaro/
No special adapters are needed to install an aftermarket headunit with the Monsoon system. I've done 100 of them. Are you POSITIVE they were working with the stock headunit? Maybe disconnect the harnesses and plug the stock headunit back in. Do they work now?
C3 - White 10-pin connector
11 - GRAY - (Convertible) amplifier sensor
12 - not used
13 - not used
14 - DARK BLUE - steering wheel controls input
15 - not used
16 - DARK GREEN w/WHITE - (Camaro) vehicle speed sensor input for automatic volume
17 - LIGHT BLUE - right rear speaker negative
18 - DARK BLUE - right rear speaker positive
19 - YELLOW - left rear speaker negative
20 - BROWN - left rear speaker positive
This is the connector i cannot plug into
Then you have either simply not plugged it into the radio harness correctly or you have purchased the incorrect harness from Best Buy, Circuit City, WalMart or where ever you bought it. There are two plugs that look just like that behind the factory radio. They stack on top of each other and almost click into place, making one larger plug. That entire thing will plug right into the correct harness from any of the above mentioned stores.
And if you haven't solved this yet, the correct harness you need is Metra part# 1858. Should come in a red bag or atleast have a large red label across the front. (Metra is getting cheap lately) That number will be proceeded by "70-" meaning it has bare wires on one end of the harness, or "80-" meaning it has a universal speed plug on one end. Either will work. They're the same thing.
Please be sure you understand what I am saying here.
There are two plugs that look just like that behind the factory radio. They stack on top of each other and almost click into place, making one larger plug. That entire thing will plug right into the correct harness from any of the above mentioned stores.Last edited by 96firebird311; 05-29-2008, 09:39 PM.
the extra connector was probably for the cd changer or the steering wheel controls
IIRC i have an extra connector back there also, and i also have a connector plugged into the "button" where 2nd gear start would be on the automatics
