dvd player audio help - FirebirdV6.com/CamaroV6.com Message Board
  • dvd player audio help
    Okay while installing my digital converter box in my car I must have unplugged something and I can't figure it out but I have an idea.
    My problem is that I can watch my dvds but I can't hear them now there is three rcas they are yellow red and white. Whenever I hook up the yellow rca I can watch my dvds but I can't hear them I figure its the red and white rcas because they are not hooked up to anything. I took one of my speakers from my computer outside and hooked one of the rcas to it and I could hear the sound but there isn't anything for me to hook up the white and red rcas to. Is there anything that I can tap into to make my sound come back for my dvd player volume to work again this is really upsetting me because it use to work really good I have a cd player also but the sound works good and loud help please
    Re: dvd player audio help
    aw man now the radio dosen't work anymore and Im blowing fuses by the second I guess I will have to take the car to a professional
      The yellow video plug is commonly called composite video. The red/white RCAs are for left/right audio signals. Without those plugged in, you'll never get audio out.
      What headunit are you using? It has one full set of audio/video inputs (for your DTV) and a second, only video, input? If so, it's probably designed for a rear-view camera or something that doesn't require sound.
      Maybe RCA y-cables on each of the connections? Turn the DTV off and then the DVD player on? And vice versa obviously...
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        and thats exactly what I have a back up camera that works also but no sound I will have everything back together before friday
          never mind everything works I guess my battery died
