I Just hooked up a Pioneer DEH-P4600MP head unit(used) in my 95 camaro. I can here this high pitch whine coming from all the speakers running off of my second amp any one know what this is? It never did this with my kenwood i had hooked up
HU Problem
Re: HU Problem
you can get a ground loop isolator from you local audio store; hook it up behind the HU and give it a good ground (I did the metal casing on the HU) and it should stop the whine.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Re: HU Problem
Ground loop isolaters dont always work. It's sort of hit N miss.
In my experience, ive seen this happen a dozen or more times, when running an amplifier off your RCA's one of the RCA's isnt properly grounded.
Try this,
try taking a wire, grounding one side, and taking the other side with exposed wire and holding it against each of the RCA' outputs one at a time to see if the problem goes away.
I had a whine that wouldnt go away, it was terrible, I tried 3 different isolators, i kept improving and relocating my grounds, switched amps, everything and it still did it.
Grounded one of my RCA's on the back of the headunit and the problem went away.
Since I found the problem, Ive found it alot. Im not sure if it's just with pioneers but thats all Ive seen it on.*Matt
