remote turn on wire - FirebirdV6.com/CamaroV6.com Message Board
remote turn on wire
  • remote turn on wire
    im trying to wire my remote turn on for my new amp, but the power antenna wire is completely missing from the harness. what do i do? the amp doesnt work without the remote turn on.
    1999 v6 Camaro M5
    Automatic to Manual converted
    Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
    !cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
    Re: remote turn on wire
    Wire it to ignition. The amp will turn on/off with the car.
    EDIT: Yellow wire on the factory harness. Red wire in the aftermarket harness(es).
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      i did that, but that wire is only pulling 9v...which doesnt sound right lol
      1999 v6 Camaro M5
        It's not. I don't know where you tapped in, but test for voltage before you tap. Then again after you tap. Maybe try with the car running and the alternator spinning. Maybe your battery is weak as all hell. Don't know what else I can tell you. You know that's not correct.:)
        Red 96' A4 Firebird
        Check it out here!
          about to do the same. this is the yellow behind the radio? or is there a more convient place?
            If you have an aftermarket headunit, the turn-on wire is blue/white coming from headunit.
            If you have the stock headunit and a power antenna, you can use the pink wire.
            If you have the stock headunit and a regular antenna, you can use the yellow wire.
            In order of preference.
            Red 96' A4 Firebird
            Check it out here!
              ehhhhh
              I have a regular antenna, but I found a wiring harness in the trunk for a power antenna (red, black, pink). Hooked it up, but didn't test for volts first. whoops. Crossing my fingers
