im trying to wire my remote turn on for my new amp, but the power antenna wire is completely missing from the harness. what do i do? the amp doesnt work without the remote turn on.
remote turn on wire
Re: remote turn on wire
i did that, but that wire is only pulling 9v...which doesnt sound right lol1999 v6 Camaro M5
Automatic to Manual converted
Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
!cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
It's not. I don't know where you tapped in, but test for voltage before you tap. Then again after you tap. Maybe try with the car running and the alternator spinning. Maybe your battery is weak as all hell. Don't know what else I can tell you. You know that's not correct.:)
If you have an aftermarket headunit, the turn-on wire is blue/white coming from headunit.
If you have the stock headunit and a power antenna, you can use the pink wire.
If you have the stock headunit and a regular antenna, you can use the yellow wire.
In order of preference.
Originally posted by 96firebird311 View PostIf you have an aftermarket headunit, the turn-on wire is blue/white coming from headunit.
I have a regular antenna, but I found a wiring harness in the trunk for a power antenna (red, black, pink). Hooked it up, but didn't test for volts first. whoops. Crossing my fingers
