Back Sail - FirebirdV6.com/CamaroV6.com Message Board
Back Sail
  • Back Sail
    So Questions,
    My friend has a 99 bird and the driver said "sub" is blowin and its 6 inch correct? Can i drop in 6.5s with out modding or cutting? Or is there a direct replace ment for these "subs"
    Re: Back Sail
    http://mods.firebirdv6.com/stereo.html#FBAQ_1
    If you have "subs" back there, surely you have the Monsoon system. You will need a 2 ohm replacement speaker. Also, any speaker you put back there will only receive low frequencies from the stock amp.
    http://www.edesignaudio.com/product_...products_id=33
    The dual 4 ohm (D4) version is what you need. They are sold individually. You'll also need to add a small spacing ring when installing them, as they are a touch too deep to just drop in.
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      Re: Back Sail
      How thick is your spacer ring?
      Lounge Moderator
        Re: Back Sail
        That's not my car, but here's a better pic:
        Looks about 1/2". If you don't feel like making them out of wood, most install shops sell 6 1/2" plastic spacer rings. I've seen up to 1.5" thick rings. Like $18 pair.
        Red 96' A4 Firebird
        Check it out here!
          Re: Back Sail
          there's some bazookas floating around that are supposed to be comparable. I will probably buy the EDs though, depending on hwat type of price I get them for in about 3 weeks
          Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
            Re: Back Sail
            Yeah, but they were out of stock. Couldn't find them on eBay either.
            Red 96' A4 Firebird
            Check it out here!
              Re: Back Sail
              you cna get the bazookas on their website, but I choose to not post this on here. They do not take a spacer, but I believe the sound quality of the EDs is just slightly better
                Re: Back Sail
                So there are replacements taht will just drop in and fir perfectly without any modification or work, and those are made by Bazooka?
                  Re: Back Sail
                  That's what he said.
                  Red 96' A4 Firebird
                  Check it out here!
